Pol
Въпрос за модул
Здравейте. Бих искал някой да ми помогне, понеже нямам необходимата програма. Интересува ме каква е разликата между два комфорт модула. Единият е с номер 8E0 959 443 AS, а другият е 8Е0 959 433 AC. Има някаква разлика в поддържането на някои функции, но не знам каква е. Благодаря предварително!
Share this post
Link to post
Не са взаимозаменяеми, ако това ти е идеята. Другата разлика е, че AC поддържа фабрична аларма, а AS не.
Central locking (Version I * - the end of June 2002, to VIN 8E * 3 * 100000):
8E0 959 433 AC - factory alarm, 433MHz, rear power windows
Central locking system (version II * - from July 2002, the VIN 8E * 3 * 100001):
8E0 959 433 AS - 433 MHz, power windows in the rear.
 * - In B6 are two different models of the central locking system - are not compatible. Looking for a replacement unit should be guided by this division (of comfort with the purchase of another version, such as AQ and the unit had bought BA - will result in the inability to assign a key to a PBX).
Ето по какво да се ръководиш, като си търсиш модул:
MODULE 8E0 959 433
7AA = Electronic vehicle immobilization device
7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection
7AN - same as 7AL only without the control of the interior.
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
5D2 = Carrier frequency 315 MHz
5D3 = Carrier frequency 315 MHz with reduced transmitting power
5D4 = Carrier frequency 315 MHz without panic button
- Factory alarm (or lack thereof)
- Frequency remote central locking (315MHz - code equipment 5D2, 5D3 and 5D4 - used in the countries of China, Singapore, Brazil, Malesia, Brunea, Japan, Korea, Bahrain, Oman, Saudi Arabia and Mexico / / 433MHz - the rest of the world, equipment code 5D1)
- Support for space lighting package legs (or none)
- Power windows at the back or crank
Identification of individual components:
- Frequency (see codes of equipment, although 99% of cases it will be 433MHz)
- Feet of space lighting package (if you do not have extra lights, does not mean that our module does not support them. Why VAG-negative is the comfort module - 46 Convenience, enter the adaptation and on channel 61 trying to save the value of 2 using the SAVE button. Re-enter adaptation - channel 61 again and this time by pressing the READ check if a value of 2 is saved. If you do not write - not comfort handle additional lighting).
- Factory alarm (if you have the codes will be equipment or 7AN 7AL symbol - it is a variant with or without the control of the interior. In the pocket of the driver's door trim panel must be deactivated with a button each alarm function)
Throwing in your description - write driver model as well as a / the things you have in autku, for example, for me it will be:
8E0 959 433 BD - factory alarm, 433MHz, leg space lighting package, rear power windows
Tree next driver comfort for the body B6:
The list of modules for B6:
8E0 959 433 J - 433MHz, lighting package over the legs, crank
8E0 959 433 K - 433 MHz, power windows at the back (or crank).
8E0 959 433 L - 433MHz, leg space lighting package, rear power windows
8E0 959 433 N
8E0 959 433 Q
8E0 959 433 R
8E0 959 433 S
8E0 959 433 T
8E0 959 433 AA
8E0 959 433 AB - factory alarm, 433MHz, rear power windows
8E0 959 433 AD - 433 MHz, power windows at the back (or crank).
8E0 959 433 AE - 433MHz, rear power windows
8E0 959 433 AF - 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 AG
8E0 959 433 AH - factory alarm, 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 AJ - factory alarm, 433MHz, leg space lighting package, rear power windows (or crank).
8E0 959 433 AK - factory alarm, 433MHz, leg space lighting package, rear power windows
8E0 959 433 AL - factory alarm, 433MHz, crank
8E0 959 433 AM - 433 MHz, packet feet of space lighting, crank
8E0 959 433 AN
8E0 959 433 AP - 433MHz, rear power windows
8E0 959 433 AQ - 433MHz, crank
8E0 959 433 AR - 433 MHz, power windows at the back (or crank).
8E0 959 433 AT - 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 BA - 433MHz, leg space lighting package, rear power windows (or crank).
8E0 959 433 BB - factory alarm, 315MHz, leg space lighting package, power windows in the rear.
8E0 959 433 BC - factory alarm, 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 BD - factory alarm, 433MHz, leg space lighting package, rear power windows (or crank).
Tree next driver comfort for the body B7:
The list of modules for B7:
8E0 959 433 BG - 433MHz, the crank (or electrician).
8E0 959 433 BH - 433 MHz, power windows in the rear.
8E0 959 433 BJ - 433MHz, leg space lighting package, rear power windows
8E0 959 433 AB
8E0 959 433 BL
8E0 959 433 BM - factory alarm, 433MHz, leg space lighting package, rear power windows
8E0 959 433 BN - factory alarm, 433MHz, crank
8E0 959 433 BP - 433 MHz, power windows at the back (or crank).
8E0 959 433 BQ - 433MHz, power windows in the rear.
8E0 959 433 BR - 433MHz, leg space lighting package, rear power windows
8E0 959 433 BS - 433MHz, leg space lighting package, rear power windows (or crank).
8E0 959 433 BT - factory alarm, 315MHz, leg space lighting package, rear power windows
8E0 959 433 CA - faryczny alarm, 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 CB - factory alarm, 433MHz, leg space lighting package, rear power windows (or crank).
8E0 959 433 CC - 433 MHz, power windows at the back (or crank).
8E0 959 433 CD
8E0 959 433 CE - 433 MHz, leg space lighting package, rear power windows
8E0 959 433 CF
8E0 959 433 CG - factory alarm, 315MHz, leg space lighting package, rear power windows
8E0 959 433 CH - factory alarm, 433MHz, rear power windows
8E0 959 433 CJ - factory alarm, 433MHz, leg space lighting package, electric rear windows (or crank).
8E0 959 433 CK - 433MHz, crank
8E0 959 433 CL
8E0 959 433 CM
8E0 959 433 CN - 433MHz, lighting package over the legs, crank
8E0 959 433 CP
8E0 959 433 CQ
8E0 959 433 CR
Encoding module comfort
Select option CODING 07 (to activate the functions we add to each other the following values ??and their sum is written as a driver coding):
1 - alarm activation (version for UK and Ireland)
2 - confirmation of the activation / deactivation of the alarm signal by the corresponding diodes in the driver's door
4 - Selective central locking (when opening the car with the remote control, a button will only open the driver's door, fuel filler flap and turn off the function of SAFE - the second press will open the other door locks and unlocks the bonnet and boot)
8 - Alarm activation
16 - Lock tailgate lock beyond 5km / h (the lock will unlock automatically when you release below 5km / h)
32 - lock all the door locks after crossing the 10km / h (locks are opened only after removing the key from the ignition, or by manually opening the door by pressing the central locking in the driver's door panels)
64 - Activate additional comfort module functions (the ability to open / close windows and sunroof with the door lock and remote control)
128 - a vehicle with a left hand drive
256 - activation-break sensors, rear side windows (only for the Avant body equipped with factory alarm)
512 - Confirmation of successful closure of all locks with the remote control by a single blink turn signals
1024 - further confirmation of the alarm activation by a single beep from the alarm siren
2048 - rules concerning the power window lifts (after turning off the ignition and removing the key from the ignition window winders will be fed for another 10 minutes or until you open the door)
4096 - Additional features burglar When you open the car key will unlock only the driver's door, other doors and locks will be unlocked after the ignition. If the car has a factory alarm when you open the driver door key - the ignition must be switched on within 15 seconds (otherwise it will release an alarm).
8192 - disable SAFE (only for USA and Canada - versions of cars designed for this market have only one engine in the castle, the other cars have two - one lock closes and the second activates the SAFE or the inability to unlock the car from the inside - the switch in the upholstery driver's door - after closing the car remote control or key)
16384 - Information for motors mounted shaft with double-layer glass
Adaptation Module comfort
Option Module comfort - ADAPTATION 10, channel 61:
0 - no additional lighting over the feet, the rear door windows in electrical
1 - without additional lighting over the foot, glass rear door cranks
2 - additional lighting feet, rear door windows in electrical
3 - additional lighting foot, glass rear door cranks
Activation of the options of comfort - ADAPTATION 10, channel 62:
1 - Comfortable remote window closing
2 - Comfortable remote control to open windows
4 - comfort closing windows key
8 - Comfortable open windows key
16 - Comfortable remote closing of sunroof
32 - Comfortable remote control opening sunroof
64 - Comfortable closing sunroof key
128 - Comfortable key opening sunroof
The last two letters are revsion numbers for the part, From Vag-com the 8E0-959-433 modules are as follows;
8E0-959-433-MIN.LBL,8E0-959-433-J ; MIN
8E0-959-433-MIN.LBL,8E0-959-433-K ; MIN
;8E0-959-433-L ;
8E0-959-433-MIN.LBL,8E0-959-433-N ; MIN
;8E0-959-433-Q ;
;8E0-959-433-R ;
;8E0-959-433-S ;
8E0-959-433-MAX.LBL,8E0-959-433-T ; MAX
;8E0-959-433-AA ;
;8E0-959-433-AB ;
8E0-959-433-MIN.LBL,8E0-959-433-AC ; MIN
8E0-959-433-MIN.LBL,8E0-959-433-AD ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-AE ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-AF ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-AG ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-AH ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-AJ ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-AK ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-AL ; MIN
8E0-959-433-MIN.LBL,8E0-959-433-AM ; MIN
;8E0-959-433-AN ;
8E0-959-433-MAX.LBL,8E0-959-433-AP ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-AQ ; MIN
8E0-959-433-MIN.LBL,8E0-959-433-AR ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-AS ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-AT ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-BA ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-BB ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-BC ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-BD ; MIN
8E0-959-433-MIN.LBL,8E0-959-433-BG ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-BH ; MAX
;8E0-959-433-BJ ;
;8E0-959-433-BK ;
;8E0-959-433-BL ;
8E0-959-433-MAX.LBL,8E0-959-433-BM ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-BN ; MIN
8E0-959-433-MIN.LBL,8E0-959-433-BP ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-BQ ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-BR ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-BS ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-BT ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-CA ; MAX
;8E0-959-433-CB ;
8E0-959-433-MIN.LBL,8E0-959-433-CC ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-CD ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-CE ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-CF ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-CG ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-CH ; MAX
8E0-959-433-MIN.LBL,8E0-959-433-CJ ; MIN
8E0-959-433-MAX.LBL,8E0-959-433-CK ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-CL ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-CM ; MAX
;8E0-959-433-CN ;
8E0-959-433-MAX.LBL,8E0-959-433-CP ; MAX
8E0-959-433-MAX.LBL,8E0-959-433-CQ ; MAX
Adding a MAX version usually would add more functionality but only replace it with a newer revision. As in BQ is max and BR max should be compatible.
Share this post
Link to post
Здравейте, искам да попитам за комфорт модул с номер 8E0 959 433 AD, какъв номер ще е съвместим, т.е с какви завършващи букви. По горният коментар разбирам,че би ми свършил работа и модул с номер  8E0-959-433-AE , или не? Моля ,ако някой може да ми помогне ще съм благодарен.
Share this post
Link to post
Hello, I have problems with my 8E0 959 433 CR on audi a4 b7 and can't find CR to buy.
With what can I replace it?
thanks
Share this post
Link to post
Здравейте, комфорт модул с номер 8е0959433N може ли да бъде заменен с друг номер или не става?
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
