VCDS - грешки и отстраняване
Тома
Създавам тази тема, за да може всеки който има нужда от помощ за разгадаването на грешките през VCDS и тяхното отстраняване да пише тук, а не да създава отделна тема за всяка една грешка. Имам същата тема и в раздел a3/8p. Ето и моят ферман с грешки:
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CCWA)       Labels: 059-907-401-CAP.clb
   Part No SW: 8K2 907 401     HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H02 0006
   Revision: 15H02---
   Coding: 010C002C191F0928
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM30TDI0118K2907401 001006
   ROD: EV_ECM30TDI0118K2907401.rod
   VCID: EADBA4230D8AB24EAA7-80BF
1 Fault Found:
4865 - No Communication with Towing System Control Module (J345)
          U1003 00 [047] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 225068 km
                    Date: 2016.01.13
                    Time: 16:19:32
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8K0 927 158 A    HW: 0B6 927 156
   Component: 0B6 30 TDIRdW H04 0050
   Revision: --H04---
   Coding: 001001
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 3467FA5B9FCEB4BE40B-8061
3 Faults Found:
4776 - Steering Column Control Module
          U0212 00 [032] - No Communications
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 15
                    Mileage: 225496 km
                    Date: 2016.01.21
                    Time: 17:22:06
2532 - Power Supply Terminal 15
          P3325 00 [032] - Implausible
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 17
                    Mileage: 225496 km
                    Date: 2016.01.21
                    Time: 17:22:06
2463 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 15
                    Mileage: 225496 km
                    Date: 2016.01.21
                    Time: 17:22:06
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 AN    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0100
   Revision: --------    Serial number: --------------
   Coding: 140D08
   VCID: 8501F79F0CD47D36275-80D0
3 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 178
                    Mileage: 227541 km
                    Time Indication: 0
                    Date: 2016.02.21
                    Time: 15:49:51
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0032
                    Hex Value: 0x0294
                    Hex Value: 0x00FF
01771 - Control Module for Headlight Range (J431)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 152
                    Mileage: 226449 km
                    Time Indication: 0
                    Date: 2016.02.08
                    Time: 07:41:53
             Freeze Frame:
                    Hex Value: 0x00C0
                    Hex Value: 0x00A2
                    Hex Value: 0x0035
                    Hex Value: 0x1077
                    Hex Value: 0x00FF
02214 - Tire Pressure Warning
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 179
                    Mileage: 228210 km
                    Time Indication: 0
                    Date: 2016.03.07
                    Time: 20:10:22
             Freeze Frame:
                    Hex Value: 0x7A00
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x1FB1
                    Hex Value: 0x00FF
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0160
   Revision: A1000000    Serial number: 01140720091918
   Coding: 36180000
   VCID: 7DF11F7FE404B5F6FF5-8028
3 Faults Found:
00457 - Control Module for Network (J519)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 177
                    Mileage: 227541 km
                    Time Indication: 0
                    Date: 2016.02.21
                    Time: 15:49:42
01321 - Control Module for Airbags (J234)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 177
                    Mileage: 225496 km
                    Time Indication: 0
                    Date: 2016.01.21
                    Time: 17:22:09
00256 - A/C Pressure/Temperature Sensor (G395)
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 227882 km
                    Time Indication: 0
                    Date: 2016.02.27
                    Time: 10:41:12
             Freeze Frame:
                    Temperature: 11.0°C
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000426578
   Coding: 260050914034AF010001000300001D0D0F1C470802010101000000
   Shop #: WSC 68012 141 80357
   VCID: 3C77D27BBF9E7CFE88B-8069
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110709  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
5 Faults Found:
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 178
                    Mileage: 227882 km
                    Time Indication: 0
                    Date: 2016.02.27
                    Time: 10:41:00
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 227882 km
                    Time Indication: 0
                    Date: 2016.02.27
                    Time: 10:41:00
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 227882 km
                    Time Indication: 0
                    Date: 2016.02.27
                    Time: 10:41:00
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 227882 km
                    Time Indication: 0
                    Date: 2016.02.27
                    Time: 10:41:00
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 227882 km
                    Time Indication: 0
                    Date: 2016.02.27
                    Time: 10:41:00
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90315IG3000DN
   Coding: 000097
   VCID: 3E73D873A9826EEEA6F-806B
   Component: E221 - MFL  H01 0003
1 Fault Found:
02797 - Control Module for Directional Stabilization Assistance (J759)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 16
                    Reset counter: 178
                    Mileage: 225496 km
                    Time Indication: 0
                    Date: 2016.01.21
                    Time: 17:22:05
Address 18: Aux. Heat (J364)       Labels: None
   Part No SW: 8R0 265 105 A    HW: 8R0 265 105 A
   Component: Standheizung  H11 0110
   Revision: 12001001    Serial number: 20090708072043
   Coding: 5D0000
   VCID: 2E53E83379E29E6E36F-807B
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 16
                    Reset counter: 178
                    Mileage: 225496 km
                    Time Indication: 0
                    Date: 2016.01.21
                    Time: 17:22:05
             Freeze Frame:
                    Temperature: 28.0°C
                    Temperature: 58.0°C
                    Voltage: 11.80 V
                        OFF
                    Error Code: 0
                    Temperature: -9.0°C
                    RPM: 0 /min
                        Yes
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0101
   Revision: FB800054    Serial number: 5400F0961681A1
   Coding: 00C303
   VCID: 800FE68B13F6581E143-80D5
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
1 Fault Found:
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 177
                    Mileage: 227541 km
                    Time Indication: 0
                    Date: 2016.02.21
                    Time: 15:49:48
             Freeze Frame:
                    Bin. Bits:    10010
                    Voltage: 11.90 V
                    Count: 7
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0321
   Revision: 00002001    Serial number: 0119979643
   Coding: 013A0620203900140120020000000000
   Shop #: WSC 06342 000 00000
   VCID: 8109E38F18FC51161BD-80D4
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS133  H06 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS228  H06 0041
2 Faults Found:
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 178
                    Mileage: 224899 km
                    Time Indication: 0
                    Date: 2016.01.09
                    Time: 16:23:58
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 15
                    Reset counter: 178
                    Mileage: 225496 km
                    Time Indication: 0
                    Date: 2016.01.21
                    Time: 17:22:05
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 10000000280708
   Shop #: WSC 00000 000 00000
   VCID: 3467FA5B97CEB4BE40B-8061
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 15
                    Reset counter: 178
                    Mileage: 225496 km
                    Time Indication: 0
                    Date: 2016.01.21
                    Time: 17:22:05
             Freeze Frame:
                    Voltage: 11.90 V
                    Count: 67
                    Speed: 0.0 km/h
                    Hex Value: 0x02F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 33
                    Reset counter: 178
                    Mileage: 222715 km
                    Time Indication: 0
                    Date: 2015.07.10
                    Time: 22:44:00
             Freeze Frame:
                    Voltage: 11.80 V
                    Count: 48
                    Speed: 0.0 km/h
                    Hex Value: 0x02E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 177
                    Mileage: 227541 km
                    Time Indication: 0
                    Date: 2016.02.21
                    Time: 15:49:45
             Freeze Frame:
                    Voltage: 12.10 V
                    Count: 58
                    Speed: 0.0 km/h
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 8T1 035 666 M    HW: 8T1 035 666 D
   Component: H-BN-EU       H41 0187
   Revision: --------    Serial number: 483G8097528995
   Coding: 010100010106A3ED09002F1E000000030000
   VCID: 4487AA9BC76E043EF0B-8011
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
1 Fault Found:
03175 - Invalid Data Set
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 150
                    Mileage: 228690 km
                    Time Indication: 0
                    Date: 2016.03.12
                    Time: 13:48:17
             Freeze Frame:
                    Voltage: 14.60 V
  • Отговори 67
Грешка номер 1 е за теглич който така или иначе няма да се използва, а от модул 5F е получена след актуализация на навигацията предполагам. Всичко друго не съм пробвал да го изтрия, понеже не пипам нищо преди да питам!
От януари е колата без камера с преден и заден парктроник е... модулите без грешки ги изтрих от лог-а че стана 3 километра дълъг. Ще изтрия всички тогава и ще направя ново сканиране. Да видим какво ще остане. Мисля че повечето от тях са се появили когато и сложиха алармата.
Sent from my Xperia Z5c using Tapatalk
Да авант е колата. Реших да ти спестя голямото скролване през всички модули, но не се замислих че това може да доведе до грешни асоциации. :)  Има бутон на лостчето на темпомата (lane assist), не знам дали е пряко свързан с тази грешка, понеже не знам какъв хардуер изисква този асистент. Но определено нямам камера нито отпред, нито отзад. Може би утре няма да имам време да се заиграя с колата, но понеделник ще изчистя всичко и каквото остане ще го пост-на тук.
Грешката от 5f предполагам че е от актуализацията на навигацията. Не знам защо, но не можах да я отстраня... ползвах ето този генератор http://www.audienthusiasts.com/Application_SVMError.html .
Няма ядове congo, успях да намеря инфо-то в гугъл от френския форум. Грешката invalid data set е вече в историята. Остана само да разреша грешката от ENGINE. Предполагам някой CAN кабел се е прекъснал до Towing control module или той е заминал като цяло.
Публикувано (Редактирано)
Виждам че модула е зад някоя от корите в багажника, но не мога да преценя на снимката. Моята ELSA няма база данни за а4 б8 да го проверя точно къде е. :wall: А софтуерно не мога ли да го дезактивирам? Интересното е че теглич нямам. Гледах под бронята и видях че стърчи едно кабелче, не можах много добре да го огледам.
Редактирано от Тома
6d79863d5e2e46f5fda15f7010a5db3f.jpg Аз не виждам да има съответния модул...Правя си заключение че колата е имала теглич но е махнат. Довечера ще дам кодинга.
Не обърнах внимание, но точно на това ми прилича и на мен. Изглежда ПВЦ, не е текстилен като твоя. Ето го и кодинга:
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840920102393
   Coding: 100103
   VCID: 408FA68BD376181ED43-8015
No fault code found.
Странно... Въобще не мога да го променя. И с yes и с no не става. Снимките са от yes.
П.с промените ги правя на запален двигател, иначе не ми дава да влезна в контролер engine.
Редактирано от Тома
На контакт, когато сложа ключа в гнездото ми излиза това (1 снимка). Не знам какъв е проблема (кабела или нещо друго), но нямам достъп. На втората снимка, не мога да променя WSC на 12345 в сиво е. Може би аз да не правя нещо както трябва.
Редактирано от Тома
Намерих нещо интересно в менюто на Mmi. 21a1278156a39113c48289d7b6b6fe59.jpg
Trailer, може би от тук ми идва проблема.
Искам да си регулирам осветлението от Mmi, но стои в сиво. Настроих в carmenuoperation на 5 и cardevicelist отметка на interior light.ccf72da11db5b19b5ddb7f23dfb944b4.jpg
Редактирано от Тома
Благодаря, интересното е че бачкат лампите в краката. Но няма на дръжките на вратите. Не вървят ли към светлинния пакет? Междувременно търся и в нет-а решение за грешката на 01,когато имам време. :)
Малко noob се получи това с контакта, не го знаех. Това е пречило да се кодира 01. Благодаря отново congo, ако всички хора са услужливи като теб ще е супер.
e8ca2df53796da4a11bf83dcb2e9124f.jpg Тук ги имах и двете отметки, трябва ли да сложа и на долния ред за да мога да контролирам осветлението от mmi.
Редактирано от Тома
  • 1 month later...
  • 1 year later...
Здравейте Колеги,
Вчера ми се случи доста странна аномалия с колата(B8 2.0TDI 143 12.2011). Напълних до горе на бензиностанцията, тръгнах и веднага започнаха една след друга да светят лампи по таблото (грешка на ръчната, esp, подгревните свещи, check engine, таблото спря да функционира, MMI изгасна, парктроника спря да работи, ключа не можеше да се извади и тн. Прибрах я някакси, първо помислих да не са ми сипали бензин вместо дизел, защото стана непосредствено след бензиностанцията, но проблема може би е електрически. Направих няколко сканирания, после махнах клемата на акумулатора, изчистих всичко и сега нищо не свети и колата работи, но не съм я карал. В общи линии грешките бяха, че няма комуникация с повечето модули. Възможно ли е да е в акумулатора проблема, мисля, че е оригиналния, но пък не съм имал проблеми с него досега. Изпращам и лога от сканиранията (дългичък е) :)
Friday,01,September,2017,20:28:28:62939
VCDS Version: Release 12.12.0 (x64)
                Address 01: Engine       Labels: 03L-906-019-CAG.clb
Control Module Part Number: 03L 906 022 NN    HW: 03L 906 019 AL
  Component and/or Version: R4 2,0L EDC   H35 9096
           Software Coding: 12194012243401080000
            Work Shop Code: WSC 06334 000 00000
              ASAM Dataset: EV_ECM20TDI03L906022NN A02011 (AU48)
                      VCID: 7EF31873E102AEEEE6F-802B
12 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:55:12
4699 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:55:12
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [040] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
          U1003 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4713 - No Communication with ABS Brake Control Module
          U0121 00 [168] - -
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4714 - Steering Column Control Module
          U0212 00 [040] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4715 - No Communication with Instrument Cluster
          U0155 00 [168] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4716 - No Communications with Parking Brake Control Module
          U0128 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4719 - No Communication with Diagnostic Gateway
          U0146 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
4720 - Body Control Module (Central Electric 2)
          U0141 00 [040] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Date: 2000.00.00
                    Time: 00:00:00
Readiness: 1 2 0 0 0
fff
Data version: 20130910
Friday,01,September,2017,20:34:29:62939
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 69 72
VIN: WAUZZZ8K7CA097636   Mileage: 197980km/123019miles
05-Acc/Start Auth. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (J623-CAGA)       Labels: 03L-906-019-CAG.clb
   Part No SW: 03L 906 022 NN    HW: 03L 906 019 AL
   Component: R4 2,0L EDC   H35 9096
   Revision: 25H35---
   Shop #: WSC 06334 000 00000
   ROD: EV_ECM20TDI03L906019AL.rod
2 Faults Found:
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 197987 km
                    Date: 2017.09.01
                    Time: 20:27:07
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 197987 km
                    Date: 2017.09.01
                    Time: 20:27:07
Readiness: 0 0 0 0 1
   Part No SW: 8K0 907 379 BH    HW: 8K0 907 379 BH
   Component: ESP8 front    H04 0060
   Coding: 16CD0C
   Shop #: WSC 06334 123 12345
10 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0A00
                    Hex Value: 0x4000
                    Hex Value: 0x121F
                    Hex Value: 0x699E
                    Hex Value: 0x00FF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0A00
                    Hex Value: 0x4000
                    Hex Value: 0x1225
                    Hex Value: 0x939F
                    Hex Value: 0x00FF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0A00
                    Hex Value: 0x6200
                    Hex Value: 0x1232
                    Hex Value: 0x029F
                    Hex Value: 0x00FF
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0900
                    Hex Value: 0x6200
                    Hex Value: 0x1238
                    Hex Value: 0x66A0
                    Hex Value: 0x00FF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 7
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0900
                    Hex Value: 0x6200
                    Hex Value: 0x1235
                    Hex Value: 0x409F
                    Hex Value: 0x00FF
01517 - Control Module for Trailer/Towing Sensor (J345)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0900
                    Hex Value: 0x6200
                    Hex Value: 0x1238
                    Hex Value: 0x43A0
                    Hex Value: 0x00FF
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0100
                    Hex Value: 0x6200
                    Hex Value: 0x121C
                    Hex Value: 0x23A9
                    Hex Value: 0x00FF
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Hex Value: 0x0100
                    Hex Value: 0x6200
                    Hex Value: 0x121C
                    Hex Value: 0x23A9
                    Hex Value: 0x00FF
01330 - Central Control Module for Central Convenience (J393)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 156
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Hex Value: 0x0080
                    Hex Value: 0x2280
                    Hex Value: 0x0038
                    Hex Value: 0x1B94
                    Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100000
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 156
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Hex Value: 0x0080
                    Hex Value: 0x2280
                    Hex Value: 0x0014
                    Hex Value: 0x1394
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 CP    HW: 8K0 907 064 CP
   Component: BCM2 2.0      H05 0435
   Revision: 00002001
   Coding: 032200
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H37 0042
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
   Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01151120111526
   Coding: 34300000
   VCID: 77FD0D57C6389FA6A59-8022
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:55:14
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Time Indication: 0
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001128934
   Coding: 260050114134AF000001000300001D0D4F1C270806010101000000
   Shop #: WSC 06335 123 12345
   Component: WWS 131111  H07 0070
   Coding: 00FD11
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:00
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:00
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:00
Cannot be reached
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD0HF64D
   Coding: 30513435363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003010
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4683B093F952362EEEF-8013
   Crash sensor for side airbag; driver side:
   Serial number: 6334MSME670065131
   Crash sensor for side airbag; passenger side:
   Serial number: 6344MSME655261649
   Crash sensor for side airbag; rear driver side:
   Serial number: 6352QSME7964087CU
   Crash sensor for side airbag; rear passenger side:
   Serial number: 6362QSME7C640574N
   Crash sensor for front airbag; driver side:
   Serial number: 63732SME52620870T
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME39643F6CF
1 Fault Found:
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
   Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20111117000300
   Coding: 000017
   VCID: 4999BBAFE04CD95603D-801C
   Component: E221 - MFL  H02 0010
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Voltage: 13.50 V
                    Hex Value: 0x0000
                    Speed: 1.0 km/h
                    Steering Angle: -1.88°
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 N    HW: 8K0 920 930 N
   Component: KOMBIINSTR.   H31 0258
   Revision: 00000000    Serial number: EJC60GACC
   Coding: 030C100003000008000001
   VCID: 387FCE6B8BA650DE6C3-806D
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:08
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:08
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:09
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:12
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:12
   Part No SW: 8T0 907 468 AH    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0120
   Revision: EC101057    Serial number: 5700E11A2881B7
   Coding: 00CF07
   VCID: 871DFD9736D86F26559-80D2
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
   Component: J367-BDMHella  H03 8040
   Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Component: J532_DCDCStab  H17 0042
Address 42: Door Elect, Driver
Cannot be reached
   Revision: 00002001    Serial number: 0163162420
   Coding: 0100062020B904C08320023680000000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 156
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000018428908
   Coding: 011C02205400410001
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 156
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
   Component: EPB Audi B8   H09 0100
   Revision: 00000003    Serial number: 20000000145911
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Voltage: 13.00 V
                    Count: 87
                    Speed: 8.0 km/h
                    Hex Value: 0x0270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Voltage: 13.00 V
                    Count: 68
                    Speed: 8.0 km/h
                    Hex Value: 0x0270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Voltage: 12.90 V
                    Count: 64
                    Speed: 10.0 km/h
                    Hex Value: 0x0270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
             Freeze Frame:
                    Voltage: 12.90 V
                    Count: 67
                    Speed: 10.0 km/h
                    Hex Value: 0x0260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
Address 55: Xenon Range (J431)       Labels: None
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 111109-0002-097
   Coding: 1172941010020300
   ASAM Dataset: EV_HeadlRegulBasic 005001
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D51EF3F7CE4E5760F5-8078
7 Faults Found:
0001 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
0011 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
0051 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
332549 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
336909 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 156
337156 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
340484 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Date: 2017.09.01
                    Time: 19:30:07
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 056 H    HW: 4G0 035 056
   Component: Radio U STD   H52 0134
   Revision: AB001007    Serial number: 469J50B7851408
   Coding: 010003020100000001
   VCID: 264310135112D62ECEF-8073
   Part No SW: 8T1 035 666 M    HW: 8T1 035 666 E
   Component: H-BN-EU       H52 0187
   Revision: --------    Serial number: 483K90B7746961
   Coding: 010100010106E3FD03002F1E000000030001
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
3 Faults Found:
03276 - Please Check Software Version Management
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 197833 km
                    Time Indication: 0
                    Date: 2017.08.27
                    Time: 19:38:22
             Freeze Frame:
                    Voltage: 12.20 V
00384 - Optical Databus
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:06
             Freeze Frame:
                    Voltage: 14.10 V
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 197833 km
                    Time Indication: 0
                    Date: 2017.08.27
                    Time: 19:38:19
             Freeze Frame:
                    Voltage: 12.20 V
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000018142417
   Coding: 010C02204000210001
   VCID: 4581B79FCC543D36E75-8010
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H09 0100
   Revision: 1A001001    Serial number: 00000162619088
   Coding: 010D000000000000
   Shop #: WSC 25397 000 00000
   VCID: 3663C05381B2A6AE7EF-8063
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 197979 km
                    Time Indication: 0
                    Date: 2017.09.01
                    Time: 19:30:07
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000018142334
End   ---------------------------------------------------------------------
Friday,01,September,2017,20:37:17:62939
2 Faults Found:
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197987 km
                    Date: 2017.09.01
                    Time: 20:32:32
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 197987 km
                    Date: 2017.09.01
                    Time: 20:32:32
  • 9 months later...
  • 1 month later...
Здравейте колеги,
напоследък ми светва лампата на ESP-то при завой ( независими наляво или надясно ) и не угасва. След като рестартирам колата лампата изчезва, но при произволен завой светва отново. Имате ли представа какъв може да е проблема? Ето го лога от VCDS:
Thursday,05,July,2018,20:04:56:56681
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.1.0.2
Data version: 20180122 DS285.1
www.Ross-Tech.com
VIN: WAUZZZ8K98A018104   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 62 72 77
VIN: WAUZZZ8K98A018104   Mileage: 223130km-138646miles
53-Parking Brake -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 B    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H01 9978
   Revision: --H01---
   Coding: 0104002C18072118
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_ECM20TDI03L906022B A01022
   ROD: EV_ECM20TDI03L906022.rod
   VCID: 24205F1B0B6AB2B995-8070
2 Faults Found:
          U1113 00 [040] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 16
                    Mileage: 223011 km
                    Date: 2018.07.03
                    Time: 17:05:37
                    Engine speed: 888.50 /min
                    Normed load value: 53.3 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 38 °C
                    Intake air temperature: 35 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 12.980 V
                    Unlearning counter according OBD: 40
                    Crankshaft speed (RPM): 1153.5 /min
                    Vehicle speed: 27.08 km/h
                    Accelerator position: 27.42 %
                    Cruise Control System: specified speed: 0.00 km/h
                    Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255
                    Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
          U1113 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 16
                    Mileage: 223011 km
                    Date: 2018.07.03
                    Time: 17:05:37
                    Engine speed: 888.00 /min
                    Voltage terminal 30: 13.000 V
                    Crankshaft speed (RPM): 1150.5 /min
                    Vehicle speed: 26.98 km/h
                    Accelerator position: 27.04 %
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AQ    HW: 8K0 907 379 AQ
   Component: ESP8 front    H03 0210
   Coding: 160500
   Shop #: WSC 06325 000 00000
   VCID: 080C076FB3F65A7DF5-805C
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 6
                    Mileage: 223004 km
                    Time Indication: 0
                    Date: 2018.07.03
                    Time: 07:55:39
             Freeze Frame:
                    Hex Value: 0x0F00
                    Hex Value: 0x4006
                    Hex Value: 0x1226
                    Hex Value: 0x23AF
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0141
   Revision: 00002001
   Coding: 030100
   VCID: 303477E7532E4A1535-8064
   Component: FBSAUDIB8 IDG  H35 0052
   Serial number: 0508000001932015
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000002297015
Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
   Part No SW: 8T1 820 043 Q    HW: 8T1 820 043 Q
   Component: KLIMA 3 ZONEN H05 0120
   Revision: C0000000    Serial number: 0124.01.080875
   Coding: 34000000
   VCID: 3F4595B46FE314FA4D-806A
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 185
                    Reset counter: 222
                    Mileage: 221137 km
                    Time Indication: 0
                    Date: 2018.05.06
                    Time: 11:08:52
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063     HW: 8K0 907 063
   Component: BCM1 1.0      H21 0253
   Revision: 01021001    Serial number: 00000000079046
   Coding: 690040B10014A7010001000000005F5F001C020800000141000000
   VCID: 6C68CF3323C2E2B1D5-8038
   Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 240108  H06 0060
   Serial number: SWFBIE 0001467
   Coding: 00FD11
   Component: RLS  H04 0002
   Serial number: 10042375
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 C    HW: 8K0 941 531 C
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001601080229
1 Fault Found:
01592 - Air Quality Sensor (G238)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 3
                    Fault Frequency: 187
                    Reset counter: 222
                    Mileage: 221137 km
                    Time Indication: 0
                    Date: 2018.05.06
                    Time: 11:08:00
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330801803309
   Coding: 100003
   Shop #: WSC 06325 123 12345
   VCID: 383C67DF73C63ACD75-806C
Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD12TFSW
   Coding: 30343434363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
   ROD: EV_AirbaECUVWAUDI010_A02.rod
   VCID: 3C386FC36BF202E155-8068
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME355601373
   Crash sensor for side airbag: front passenger side:
   Serial number: 6344MSME38031133$
   Crash sensor for side airbag: rear: driver side:
   Serial number: 6352QSME4C521B73M
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 6362QSME4C514E09R
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME4F3378253
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME50271B73-
Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
   Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90304HAF0005K
   Coding: 000016
   VCID: 3D4769CE67E918E85D-8068
   Component: E221 - MFL  H02 0003
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 13
                    Reset counter: 6
                    Mileage: 223011 km
                    Time Indication: 0
                    Date: 2018.07.03
                    Time: 17:05:37
             Freeze Frame:
                    (no units): 44.0
                    Text: 2C8FFFFFFFFF00C0FF
                    Ign. Timing: 323.9°
                    Raw, Index/Key Err.: 255 255 000
                    Text: 1A9619105000140000
                    Mass Flow: 22.89 g/s
                    Resistance: 0.20 kOhm
                    Raw, Form. N/A: 000 000 118
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 C    HW: 8K0 920 900 C
   Component: KOMBIINSTR.   H14 0216
   Revision: 00100000    Serial number: 7VL14DKD7
   Coding: 0FAD080002000008810001
   VCID: 2A2A43F53B08966FE5-807E
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA801030    Serial number: 3000G07C228086
   Coding: 000003
   VCID: 424293BD9B90E697A5-8016
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 18003CEF120108
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000006777873
   Coding: 011002205400410001
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0109128888
   Coding: 011A0620003904C0032001
   Component: DWA-Sensor  H02 0030
3 Faults Found:
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 221137 km
                    Time Indication: 0
                    Date: 2018.05.06
                    Time: 11:36:56
02616 - Fuel Tank Cap; Unlock
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 221137 km
                    Time Indication: 0
                    Date: 2018.05.06
                    Time: 11:37:05
01518 - Bulb for Back-Up Lights; Left (M16)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 223079 km
                    Time Indication: 0
                    Date: 2018.07.04
                    Time: 17:46:46
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000006769172
   Coding: 011002205000410001
   VCID: 3E466BC96BE41EF345-806A
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000059039
   VCID: 2F3575E42F33740ACD-807A
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 B    HW: 8T1 035 186 B
   Component: Concert3      H13 0130
   Revision: 00000515    Serial number: AUZ5Z6H1018388
   Coding: 0000048204018500035B070002
   VCID: 363E7BD14BCC2E3B05-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000006802770
   Coding: 010002204000210001
   VCID: 404497B7939EEA85B5-8014
Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-794.clb
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000006804216
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8T0 862 335 B    HW: 8T0 862 335 B
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005032237
   Coding: 0010340
   VCID: 393B61DAB7FD30D47D-806C
End-------------------------(Elapsed Time: 03:10)--------------------------
steer angle sensor calibrat position
steering angle main / sub controller
