vivaleo Публикувано 19 Март 2020 Доклад Share Публикувано 19 Март 2020 Имам малки проблемчета по колата които ме дразнят и си търся майстор за да ги отстрани. СОФИЯ. те са: Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl Part No: 4D0 820 043 Q Component: A8-Klimavollautomat D11 Coding: 00080 Shop #: WSC 02313 VCID: 2A5BE423D60AF24EEA7-254E 1 Fault Found: 00657 - Positioning Motor for Central Vents (V102) 41-00 - Blocked or No Voltage ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4D0-959-655-AI8.lbl Part No: 4D0 959 655 J Component: Airbag Front+Kopf 0004 Coding: 00427 Shop #: WSC 02324 VCID: 3979CB6F23AC49D693D-5072 3 Faults Found: 00656 - Seat Occupied Sensor; Passenger Side (G128) 47-10 - No Communications or Incorrectly Connected - Intermittent 00656 - Seat Occupied Sensor; Passenger Side (G128) 36-10 - Open Circuit - Intermittent 00588 - Airbag Igniter; Driver Side (N95) 32-10 - Resistance Too High - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4D0-919-033-MYX.lbl Part No: 4D0 919 033 BA Component: D2-KOMBIINSTR. VDO D19 Coding: 16183 Shop #: WSC 00000 VCID: 64C74A1BF4AE643E10B-5072 WAUZZZ4DZXN008085 AUZ7Z0X0893621 1 Fault Found: 00667 - Ambient Temperature Signal 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 G Component: ZV-Pumpe, DWA, Funk D16 Coding: 13130 Shop #: WSC 29700 VCID: 3979CB6F23AC49D693D-4DD6 1 Fault Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - Адрес на коментара Сподели в други сайтове More sharing options...
