nilnull Публикувано 1 Август 2019 Доклад Share Публикувано 1 Август 2019 Здравейте, не успявам да ресетна сервизния интервал за маслото. Пробвах най-напред през мултимедията, но нищо не стана. Тогава пробвах с кабела. Пак същата работа. Изтрих предварително всички грешки. Пробвах на контакт, пробвах с отворена врата. Пробвах различи интервали горе от падащия списък. Всичко минава ОК , но нищо не се случва. Очевидно изпускам нещо. Дайте жокер къде бъркам. Ето го и лога: Thursday,01,August,2019,20:27:41:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- VCDS Release 12.12.0: SRI Reset Control Module Part Number: 8K0 920 930 D Labels: 8T0-920-xxx-17.clb Component:KOMBIINSTR. H19 0253, Coding:030D090002000008040000 Operation: Flexible Oil Service Reset (LongLife/Great Britain/Diesel) ************************************************************************************************************************ Channel Description Unit Current val. New val. 02 Service Reminder Status 0 0 40 Distance since Service km x100 0 --- 41 Time since Service Days 0 --- 42 Minimum Distance to Service km x100 10 145 43 Maximum Distance to Service km x100 300 306 44 Maximum Time to Service Days 730 730 45 Oil Quality 1 2 47 Soot Quantity DIST x100 0 --- 48 Thermal Load DIST x100 0 --- 49 Minimum Time to Service Days 730 730 50 Basic Distance Value for Oil Change km x100 150 --- 51 Basic Time Value for Oil Change Days 365 --- 52 Basic Distance Value for Inspection km x100 160 --- 53 Distance since Inspection km x100 112 --- 54 Basic Time Value for Inspection Days 365 --- 55 Time since Inspection Days 348 --- 56 Day Counter Days 3696 --- ************************************************************************************************************************ Log-Log.txt Адрес на коментара Сподели в други сайтове More sharing options...
ShadowM Публикувано 1 Август 2019 Доклад Share Публикувано 1 Август 2019 с какъв кабел и софт го правишИзпратено от моят CLT-L29 с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
nilnull Публикувано 1 Август 2019 Автор Доклад Share Публикувано 1 Август 2019 VCDS 12.12.0 . Миналата година със същия кабел и същата програма го ресетнах. Адрес на коментара Сподели в други сайтове More sharing options...
nilnull Публикувано 2 Август 2019 Автор Доклад Share Публикувано 2 Август 2019 Успех . Намерих в един форум. 17-Instruments->ADAPTATION В канали 40, 41, 53, 55, 02 записвам нова стойност: 0. Пише, че трябва в тази последователност да се попълнят стойностите в каналите. При мен в канал с дните не се бе записало 0, като съм използвал "SRI Reset" Ето и линка : https://www.audi-sport.net/xf/threads/service-light-reset-the-solution.150225/ 1 Адрес на коментара Сподели в други сайтове More sharing options...
