nikola_slavov Публикувано 4 Март 2018 Доклад Share Публикувано 4 Март 2018 Здравейте колеги, някой да си има наидея от какво може да е породен следния проблем: Когато се подаде на контакт таблото не светва / също така и индикацийте не светят/ в момента в който запали и гасне. При прочитане грешките които е записала са: VCDS Version: Release 12.12.0 Data version: 20130910 Sunday,04,March,2018,12:22:27:62939 Chassis Type: 8P (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D VIN: WAUZZZ8PX5A008592 Mileage: 130310km/80970miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 1010 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 016 FF HW: 028 101 190 5 Component: R4 2,0L EDC 0000SG 6337 Revision: 12345678 Serial number: AUX7Z0D5FNH08V Coding: 0000072 Shop #: WSC 01286 386 08256 VCID: 6CD7223B4F7E2C7E58B-8039 1 Fault Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 000 - - MIL ON Freeze Frame: RPM: 0 /min Torque: 12.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 11.55 V Bin. Bits: 00000100 Bin. Bits: 00000000 (no units): 0.0 Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 K Component: ESP FRONT MK60 0103 Coding: 0023174 Shop #: WSC 06435 000 00000 VCID: 3A7BD46375AA42CE9A7-806F No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 D HW: 8P0 820 043 D Component: KlimavollautomatH12 0150 Revision: 061200 Serial number: 8P0820043D Shop #: WSC 00000 000 00000 VCID: 2D51EF3FB4E4E5760F5-8078 2 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 11 Reset counter: 73 Mileage: 129512 km Time Indication: 0 Date: 2018.01.13 Time: 13:29:25 Freeze Frame: Voltage: 13.20 V Temperature: 9.0°C (no units): 169.0 (no units): 30.0 Temperature: 0.5°C 01809 - Actuating Motor for Temperature Flap; Left (V158) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 16 Reset counter: 76 Mileage: 129516 km Time Indication: 0 Date: 2018.01.13 Time: 14:59:04 Freeze Frame: Voltage: 13.50 V Temperature: 24.0°C (no units): 197.0 (no units): 229.0 Temperature: 0.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl Part No SW: 8P0 907 279 A HW: 8P0 907 279 A* Component: Bordnetz-SG 1.0 H30 0501 Revision: 00030000 Serial number: 00000000817765 Coding: B3885F2F9214101E000000000400000000 Shop #: WSC 12345 123 12345 VCID: 3B75D1677A907BC6811-806E Subsystem 1 - Part No: 8P1 955 119 C Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0180 Coding: 16187408 Shop #: WSC 12345 10 Faults Found: 00526 - Brake Light Switch-F 008 - Implausible Signal - Intermittent 01505 - Bulb for Blinkers; Rear Right (M8) 012 - Electrical Fault in Circuit - Intermittent 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent 02395 - Parking Light Front Right (M3) 012 - Electrical Fault in Circuit 02104 - Light Detection Sensor (G399) 010 - Open or Short to Plus 01504 - Bulb for License-Plate Light (X) 012 - Electrical Fault in Circuit 00061 - Footwell Lights 012 - Electrical Fault in Circuit 01518 - Bulb for Back-Up Lights; Left (M16) 012 - Electrical Fault in Circuit 02394 - Parking Light Left Front (M1) 012 - Electrical Fault in Circuit 01506 - Bulb for Rear Fog; Right (L47) 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 D HW: 8P0 959 655 D Component: Airbag 8.4ED H00 0140 Coding: 0010602 Shop #: WSC 06435 000 00000 VCID: 4385A98702600306C91-8016 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksaulenmodul 012 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 306FF64BA3D6889E243-8065 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 930 K HW: 8P0 920 930 K Component: KOMBIINSTR. VDO H71 0200 Revision: D01 Serial number: 2245DD01002576 Coding: 0004108 Shop #: WSC 80093 222 69422 VCID: 3A7BD46375AA42CE9A7-806F No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 D HW: 1K0 907 951 Component: Gateway H08 0100 Revision: 08 Serial number: 250010452104C6 Coding: 3D0F0B42070100 Shop #: WSC 06435 000 00000 VCID: 285F1E2B9B06C05EFC3-807D 2 Faults Found: 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 37 Mileage: 125728 km Time Indication: 0 Date: 2017.08.10 Time: 09:31:29 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 62 Mileage: 130119 km Time Indication: 0 Date: 2018.02.17 Time: 16:09:54 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 930 K HW: 8P0 920 930 K Component: KOMBIINSTR. VDO H71 0200 Revision: D01 Serial number: AUX7Z0D5FNH08V Shop #: WSC 00000 000 00000 VCID: 3A7BD46375AA42CE9A7-806F No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Cannot be reached ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 G Component: EPS_ZFLS Kl.10 1401 Shop #: WSC 00000 000 00000 VCID: 2F6DF537BEE897663D9-807A 1 Fault Found: 00750 - Warning Lamp 013 - Check DTC Memory - MIL ON Freeze Frame: Mileage: 280 km Temperature: 13.0°C Voltage: 11.60 V Voltage: 11.40 V ------------------------------------------------------------------------------- Address 46: Central Conv. Cannot be reached ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8Px-035-382.lbl Part No SW: 8P3 035 382 HW: 8P3 035 382 Component: AB2 SUBWOOFERBOXH25 0160 Revision: 00003 Serial number: 10000001137482 Shop #: WSC 00000 000 00000 VCID: F0EFB64BE356489EE43-80A5 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 D HW: 1K0 963 235 D Component: PTC-Element 0404 Revision: 00700000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. End --------------------------------------------------------------------- Адрес на коментара Сподели в други сайтове More sharing options...
venomcorp Публикувано 4 Март 2018 Доклад Share Публикувано 4 Март 2018 Замери си акумулатора и алтернатора . Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 4 Март 2018 Доклад Share Публикувано 4 Март 2018 Проблем със захранването на таблото. От там и гасненето веднага, защото имобилайзер е в него. Още ли не можеш да запалиш колата? Адрес на коментара Сподели в други сайтове More sharing options...
nikola_slavov Публикувано 5 Март 2018 Автор Доклад Share Публикувано 5 Март 2018 (Редактирано) Да колега, още не мога Редактирано 6 Март 2018 от VBI Цитиране на предходно мнение! Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 5 Март 2018 Доклад Share Публикувано 5 Март 2018 В коя част на София си? Мога да ти помогна. Адрес на коментара Сподели в други сайтове More sharing options...
