UltimateA5 Публикувано 22 Юли 2018 Доклад Share Публикувано 22 Юли 2018 Здравейте Колеги, Първият ми пост е свързан с проблем. Знам, че правилния подход е сервиз, но ще се радвам да разбера вашето мнение по посочените по- долу грешки. Препоръки за сервиз също ще са от полза. Предварително благодаря ! Мотор : 2.0 TDI - CAHA 2 Faults Found: 5262 - Diesel Particle Filter; Differential Pressure Sensor P2454 00 [032] - Short to GND Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 14 Mileage: 160220 km Date: 2018.07.19 Time: 18:14:20 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 71 °C Intake air temperature: 37 °C Ambient air pressure: 940 mbar Voltage terminal 30: 12.020 V Unlearning counter according OBD: 40 Exhaust gas vol.flow particulate filter: 0.0 mі/h Surface temperature of filter: 184.7 °C Field regeneration status-Bits 0-7: 0 Field regeneration status-Bits 0-7: 0 Field regeneration status-Bits 0-7: 0 Field regeneration status-Bits 0-7: 128 Particle filter: difference pressure: -68 hPa Particle filter: offset for differential press.: 6 hPa Exhaust gas temp.after pre-catalyst: 194.2 °C Particle filter: kilometers since last regeneration: 0 m 5162 - Diesel Particle Filter; Differential Pressure Sensor P2453 00 [101] - Implausible Signal Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 160220 km Date: 2018.07.19 Time: 18:22:36 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 71 °C Intake air temperature: 35 °C Ambient air pressure: 940 mbar Voltage terminal 30: 13.380 V Unlearning counter according OBD: 40 Exhaust gas vol.flow particulate filter: 0.0 mі/h Field regeneration status-Bits 0-7: 0 Field regeneration status-Bits 0-7: 0 Field regeneration status-Bits 0-7: 0 Field regeneration status-Bits 0-7: 0 Particle filter: difference pressure: -62 hPa Particle filter: offset for differential press.: 6 hPa Exhaust gas temp.after pre-catalyst: 194.2 °C Particle filter: oil ash volume: 0.12 l Particle filter: kilometers since last regeneration: 0 m Readiness: 0 0 0 0 0 Адрес на коментара Сподели в други сайтове More sharing options...
@Mu Публикувано 23 Юли 2018 Доклад Share Публикувано 23 Юли 2018 Здрасти. За мене е датчик за диференциално налягане на DPF ( ако колата е на тия километри). Имах подобен проблем но на CAGA мотор и след смяната на датчика 3 г. без грижи Пробва ли регенерация ? Адрес на коментара Сподели в други сайтове More sharing options...
UltimateA5 Публикувано 23 Юли 2018 Автор Доклад Share Публикувано 23 Юли 2018 Благодаря за мнението ! Какъв трябва да е датчика - оригинален или може и алтернативен ? Как да пробвам регенерация ? Адрес на коментара Сподели в други сайтове More sharing options...
@Mu Публикувано 25 Юли 2018 Доклад Share Публикувано 25 Юли 2018 Изобщо не ми е минавало през главата да слагам алтернативен, оригинала е стотина лева в Порше без отстъпки. Адрес на коментара Сподели в други сайтове More sharing options...
Raino Публикувано 6 Август 2018 Доклад Share Публикувано 6 Август 2018 Много е важен този датчик. Лошото е, че като работи на 50% да кажем хем не дава грешка, хем пълни филтъра. Сменяйте го профилактично на 2-3г. Адрес на коментара Сподели в други сайтове More sharing options...
@Mu Публикувано 13 Август 2018 Доклад Share Публикувано 13 Август 2018 Колега какъв се оказа проблема ? Адрес на коментара Сподели в други сайтове More sharing options...
UltimateA5 Публикувано 13 Август 2018 Автор Доклад Share Публикувано 13 Август 2018 Здравейте Колеги, изчаквах да натрупам малко пробег за дам отговор. Проблема е решен, сензора беше сменен с такъв на Bosch. Благодаря за мнението и коментарите ви. Адрес на коментара Сподели в други сайтове More sharing options...
plamen 73 Публикувано 26 Октомври 2018 Доклад Share Публикувано 26 Октомври 2018 нормално ли е "Particle Filter offset different pressure" да седи на -7 постоянно Адрес на коментара Сподели в други сайтове More sharing options...
