soult@ker Публикувано 5 Май 2020 Доклад Share Публикувано 5 Май 2020 Търсих в подфорума кодинги ама няма тема, затова ще копирам от темата в audizine. Който може и иска да допълва, Фифи сигурно ще го мързи. Here's the list I've compiled so far: Disable After-wipe of windscreen wipers Disable amber corner lights Disable amber side markers Disable Key warning (keyless models) Disable LED 'wink' on turn signal Disable "Lights are on" warning Disable NAV & Phone warning messages while entering data at speed Disable Seatbelt Chime Enable Adaptive brake lights Enable Ambient Interior Lighting Control Enable Automatic Gear selection shown in DIS Enable Automatic Hill Hold Assist 'lite' Enable Auxiliary ventilation Enable Battery meter Enable DIS with Efficiency Program Enable Double Disarm Beep Enable DRL Selectable via MMI Enable DRL Enable Euro parking lights that turn on signal at night Enable fog lamp to come on for the same side as that turn signal Enable Front Turn Signals as Parking lights Enable Gauge Test/Needle Sweep Enable Hidden menu in MMI Enable Import CDs to MMI's HD Enable Independent Fogs control with high beams Enable Lap Timer Enable LEDs remain bright for parking lights Enable Rear Tail Lights on with DRLs Enable Release Parking Brake without putting foot on Brake Enable Release Parking Brake without putting seatbelt Enable Remote Operation windows&sunroof Enable Reverse mirror tilt Enable Speed through MMI Enable TPMS Enable VIM on MMI Set Audi parking system - Switch OFF Speed Set Custom ADS settings Set Headlight washer - cycles Set Headlight washer - duration Adjust Consumption in DIS Adjust LED Brightness Audi A4/S4 B8VCDS (VAG-COM) codes Disable After-wipe of windscreen wipers [09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1 Bit 3 - Remove check mark (1 = active) ________________________________________Disable amber corner lights [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10 Submodule 0 Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles) ________________________________________Disable Key warning (keyless models) [46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9 Bit 7 set to 0 (Uncheck) ________________________________________Disable LED 'wink' on turn signal [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3 Bit 2 - LEDs remain at full brightness with parking lights (1 = active) Bit 7 - Turn off LED-strip DRLs with indicators (1 = active) ________________________________________Disable "Lights are on" Warning [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5 Bit 3 - Set to 0 to disable "lights are on" warning when you open the door. ________________________________________Disable NAV & Phone warning messages while entering data at speed [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250 ________________________________________Disable Seatbelt Chime [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0 Bit 2-4 – Seat Belt Warning inactive ________________________________________Enable Adaptive brake lights [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8 Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active) Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active) ________________________________________Enable Ambient Interior Lighting Control [Hidden menu] [car] [carmenuoperation] [interior light] Set to 5 [Hidden menu] [car] [cardevicelist] [interior light] Enable Reset MMI ________________________________________Enable Automatic Gear selection shown in DIS [02 – Auto Trans] [Adaptation – 10] Select “Single Gear Display” from top channel drop down menu Select “D on/S on” from New value drop down menu ________________________________________Enable Automatic Hill Hold Assist ‘lite’ [03 - ABS brakes][Security Access - 16] (Enter code presented by program) [Coding – 07] -> Long Coding Helper -> Byte 1 Bit 6 set to 1 to enable hill hold assist.http://www.audizine.com/forum/showth...r-the-A4/page2 ________________________________________Enable Auxiliary ventilation [5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6 Bit 1 – Set to 1 [Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1 Bit 3 – Set to 1 Bit 4 – Set to 1 ________________________________________Enable Battery meter [Hidden menu] [car] [cardevextdevicelist] [Battery] Enable [Hidden menu] [car] [carmenuoperation] [Battery] Set to 5 Reset MMI or [56 - Radio] -> Adaption -> Channel 39, add 16 to your value ________________________________________Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System) [17 - Instruments] [Adaptation - 10] -> Channel 77 change 0 to 255 ________________________________________Enable Double Disarm Beep [46 - Central Conv.] [Adaptation - 10] -> Channel 63 Add 4 ________________________________________Enable DRL Selectable via MMI [09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3 Bit 5 set to 1 ________________________________________Enable DRL [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2 Bit 1 = DRL via Front Side markers Bit 2 = DRL via High Beams Bit 3 = DRL via Fogs Bit 4 = DRL via LEDs Bit 6 = DRL via Side markers Bit 7 = DRL via Tail lights ________________________________________Enable Euro parking lights that turn on signal at night [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9 Bit 0 - Set to 1 ________________________________________Enable fog lamp to come on for the same side as that turn signal [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4 Bit 0 - Check the box or change :Bit 0 set to 1 ________________________________________Enable Front Turn Signals as Parking lights [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10 Bit 0- Check the box or change :Bit 0 to 1 Once the change has been made you can enable the front turn signals as DRL's by making the following change: [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2 Bit 6 - Check the box or change :Bit 0 set to 1 ________________________________________Enable Gauge Test/Needle Sweep [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1 Bit 0 - Check the box for "Gauge Test/Needle Sweep active" ________________________________________Enable Headlights on all the time [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4 Bit 5 - Check the box or change :(Bit 5 Set to 1) ________________________________________Enable Hidden menu in MMI [5F - Information Electr.] [Adaptation - 10] -> Channel 6 change 0 to 1 Use this hidden menu at your own risk.Caution: Keep away from the "Bootloader" ________________________________________Enable Import CDs to MMI's HD [Hidden menu] Main/Diagnose/Settings Import Media Set to 4 of 4 "Copy/Ripping" ________________________________________Enable Independent Fogs control with high beams [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4 Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0 Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0 ________________________________________Enable Lap Timer [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1 Bit 3 - Check the box for "Lap Timer active" ______________________________________Enable Remote Operation Windows and Sunroof [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2 Bit 2 - Set to 1 ______________________________________Enable Rear Tail Lights on with DRLs [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2 Bit 7 - DRL's via Tail Lets Active (1 = Active) ________________________________________Enable Release Parking Brake without putting foot on Brake [53 - Parking Brake][Security Access - 16] (Enter code presented by program) [Adaptation - 10] -> Channel 4 Set to 0 ________________________________________Enable Release Parking Brake without putting seatbelt [53 - Parking Brake][Security Access - 16] (Enter code presented by program) [Adaptation - 10] -> Channel 7 Set to 0 ________________________________________Enable Reverse mirror tilt [52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 4 and Bit 2 set to 1 ________________________________________Enable Speed through MMI [56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1Does not work if NAV equiped ________________________________________Enable TPMS * You need the 1AT ABS unit – check your stickers (1AS does not work) [Hidden menu] [car] [cardevicelist] [RDK] Enable [Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5 [03 - ABS Brakes] [Security Access - 16] (probably with login code: 61378) [Coding - 07] -> Long Coding Helper -> Byte 1 Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active) The TPMS need to be enabled in the Instrument Cluster: [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 4 Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active) Reset MMI ________________________________________Enable VIM on MMI [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number [Adaptation - 10] -> Channel 48 Set to 255 Reset MMI ________________________________________Set Audi parking system - Switch OFF Speed [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23 Set to 20 (max value in km/h) ________________________________________Set ADS to specific preset Comfort, Auto, Dynamic or Individual [09 – Cent. Elect.][Security Access - 16] [Adaptation - 10] -> Channel 63 Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual [Adaptation - 10] -> Channel 64 Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual [Adaptation - 10] -> Channel 65 Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual [Adaptation - 10] -> Channel 66 Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual *Note all four channels needs to be set to the same value. ________________________________________Set Headlight washer - Duration [09 – Cent. Elect.] [Security Access - 16] [Adaptation - 10] -> Channel 6 change to e.g. 500 ________________________________________Set Headlight washer - Cycles [09 – Cent. Elect.] [Security Access - 16] [Adaptation - 10] -> Channel 26 change to e.g. 10 ________________________________________Adjust Consumption in DIS [17 - Instruments] [Adaptation - 10] -> Channel 3 change 100 to xxx (see samples below) Sample 1 - Calculation based on volume per distance (e.g. l/100km): DIS: 9,3 l/100 km. Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38) Channel 3 will be changed from 100 to 105 Sample 2 - Calculation based on distance per volume (e.g. MPG): DIS: 23 MPG. Real: 24 MPG. (100 * 23 / 24 = 95,83) Channel 3 will be changed from 100 to 96 ________________________________________Adjust LED brightness [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113) [Adaptation - 10] -> Channel 3 Set between 5 and 100 ________________________________________Set Automatic Transmission Start Mode to D or S [09 - Cent. Elect.] [Security Access - 10] [Adaptation 10] -> Channel 64 - Stored Value = 218 = Starting mode is always D Channel 64 - New Value = 00; Starting mode is determined by ADS selection at engine shutdown (Comfort and Auto=D, Dynamic=S, Individual=whatever you pick) Channel 64 - New Value = 03; Starting mode is always S regardless of ADS selection at engine shutdown (opposite of stock) Channel 64 - New Value = 11; Starting mode is S with all ADS settings at shutdown except Comfort where it's D Channel 64 - New Value = 19; Starting mode is S with all ADS settings at shutdown except Auto where it's D ________________________________________ 1 Адрес на коментара Сподели в други сайтове More sharing options...
