Кодиране ABS
Petar7894
Здравейте, ако може някой да помогне....
Смених електрониката на абса и сега не приема кодовете. Колата е А4 66 2.5 tdi спирачки Pr 1LT по етикета, С автоматична скоростна кутия Multitronic . Вкарвам 09359 за логин и 04459 за кодинг но не  приема кодинга все си остава 00000 и за това и не пристъпвам към калибриране на сензора за волана, че все нули показва.
Къде бъркам?
Note #1: After Login has been carried out you need to recode the control module.
Note #2: Special Login 09399 is used for BFB Engine with 1LT Brakes and Multitronic.
Note #3: The PR codes ( such as 1LJ ) can be found in a sticker near the spare tire well.
0?xxx: Chassis
9 = Audi A4
0x?xx: Brakes
2 = Brembo 17" (PR-1LJ)
3 = FN3 16" (PR-1LT/1LF)
4 = HP2 16" (PR-1LX)
4 = FNR 16" (PR-1LA/1LG)
5 = FN3 15" (PR-1LB/1LE)
6 = C54 (PR-1LZ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8 Cyl. Gasoline
0xxx?: Transmission
5 = Manual
7 = Automatic (5HP19, 5HP24, AG4, AG5)
9 = Multitronic
Прекодиране:
Note #1: Coding is accepted after a specific login has been carried out.
Note #2: After successful coding the steering angle sensor basic setting needs to be carried out.
Note #3: Special Coding 04499 is used for BFB Engine with 1LT Brakes and Multitronic.
Note #4: The PR codes ( such as 1LJ ) can be found in a sticker near the spare tire well.
0?xxx: Chassis
4 = Audi A4
0x?xx: Brakes
1 = C54 (PR-1LZ)
2 = FN3 15" (PR-1LB/1LE)
3 = HP2 16" (PR-1LX)
3 = FNR 16" (PR-1LG)
4 = FN3 16" (PR-1LT/1LF)
5 = Brembo 17" (PR-1LJ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
0xxx?: Transmission
5 = Manual
9 = Multitronic
Basic Setting
Steering Angle Sensor (G85) Calibration
[select]
[03 - ABS Brakes]
[Fault Codes - 02]
[Done, Go Back]
Без да излизаме от програмен режим на модула :
Turn steering wheel at least 30 ° left and back straight ahead.
После влизаме в:
[Meas. Blocks - 08]
Group 005 Field 1 (Steering Angle Sensor -G85-)
Specification: 0.0 °
Tolerance (when straight): ±5.0 °
[Done, Go Back]
[Login - 11]
Enter 40168
[Do It!]
[basic Settings - 04]
Group 001
[Go!]
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
[Close Controller, Go Back - 06]
Миналата година и аз сменях електрониката на АБС.Кодирането ми се получи от4,5 път.Номерата на новия и стария модул трябва да са напълно еднакви.Те май бяха два модела,с буква накрая и без буква.Пробваш,ако не стане почини малко и пак пробвай.До колкото прегледах правилно си написал кодирането.Ако не става пробвай да разкачиш акумулатора за няколко минути и пак пробвай.Успех
