mnay Публикувано 11 Януари 2012 Доклад Share Публикувано 11 Януари 2012 Здравейте , от скоро съм притежател на Ауди а3 2.0 ТФСИ .Нямам проблеми с автомобила , но от няколко дни климатроника се изключва когато си поиска , тоест дисплея си работи но спира да духа !!!после пак тръгва , без да мога да разбера каква може да е пречината за това . на ВагКом изписва това ...обаче нямам никаква идея какво означава .Някой може ли да помогне .Wednesday,11,January,2012,13:49:08:13314VCDS Version: Release 908.0 Address 08: Auto HVAC Labels: 8P0-820-043.lblControl Module Part Number: 8P0 820 043 K HW: 8P0 820 043 K Component and/or Version: KlimavollautomatH17 0200 Software Coding: Work Shop Code: WSC 06314 000 000005 Faults Found:01592 - Air Quality Sensor (G238) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 174 Mileage: 139212 km Time Indication: 0 Date: 2012.01.09 Time: 11:00:01 Freeze Frame: Temperature: 10.5°C01336 - Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 174 Mileage: 139227 km Time Indication: 0 Date: 2012.01.10 Time: 21:23:43 Freeze Frame: ON 00819 - High Pressure Sensor (G65) 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 174 Mileage: 139212 km Time Indication: 0 Date: 2012.01.09 Time: 11:00:01 Freeze Frame: Temperature: 3.0°C Voltage: 14.20 V RPM: 850 /min Load: 0.0 % Load: 31.0 %01336 - Data Bus for Comfort System 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 174 Mileage: 139216 km Time Indication: 0 Date: 2012.01.10 Time: 13:06:28 Freeze Frame: ON 01273 - Fresh Air Blower (V2) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 174 Mileage: 139216 km Time Indication: 0 Date: 2012.01.10 Time: 13:06:31 Freeze Frame: Temperature: 7.0°C Speed: 0.0 km/h (no units): 49.0 (no units): 169.0 Адрес на коментара Сподели в други сайтове More sharing options...
audifanatic Публикувано 11 Януари 2012 Доклад Share Публикувано 11 Януари 2012 Здравей да не би да е настроено само да се изключва при определени градуси в купето ? Адрес на коментара Сподели в други сайтове More sharing options...
mnay Публикувано 11 Януари 2012 Автор Доклад Share Публикувано 11 Януари 2012 Здравей да не би да е настроено само да се изключва при определени градуси в купето ? ами не вярвам , преди не е правил така . А и го направи при външна Температура от -3 градуса Адрес на коментара Сподели в други сайтове More sharing options...
slavista Публикувано 11 Януари 2012 Доклад Share Публикувано 11 Януари 2012 Достига до температурата , която му е зададена и спира да духа? При палене на колата ли го пусна ? Адрес на коментара Сподели в други сайтове More sharing options...
sa60_89 Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Здравейте! Реших да пиша тук вместо да създавам нова тема. След тестване за грешки излезна ето тази. Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 J HW: 8P0 820 043 J Component: KlimavollautomatH16 0200 Revision: 060997 Serial number: 8P0820043J Shop #: WSC 06314 000 00000 VCID: 33699CCF0235689BCE1-8066 1 Fault Found: 01592 - Air Quality Sensor (G238) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 133 Mileage: 162029 km Time Indication: 0 Date: 2016.09.06 Time: 00:11:57 Freeze Frame: Temperature: 30.0°C Какъв е този сензор/датчик и каква функция изпълнява? Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Сензорът следи колко е замърсен въздухът и затваря клапата за рециркулация, когато караш зад Икарус. Адрес на коментара Сподели в други сайтове More sharing options...
venomcorp Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 В неговият случай е за смяна. Изпратено от моят LG-D855 с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Не е задължително. Нека изчисти грешката и да покара седмица, две. Тогава пак да го провери. Адрес на коментара Сподели в други сайтове More sharing options...
ivan32 Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Чистя грешката и веднага излиза на следващия тест, без да съм движил колата дори.Най-вероятно ще е за смяна.Има ли начин като го сваля, да се замери дали има живот в него? Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Като за начало виж дали въобще е закачен. Намира се под кората на чистачките, в ляво. Там от където влиза въздухът в купето. Адрес на коментара Сподели в други сайтове More sharing options...
venomcorp Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Добре де ако не е закачен или ако е лоша връзка няма ли да изписва друга грешка , а не - Defective ??? Адрес на коментара Сподели в други сайтове More sharing options...
joro09 Публикувано 29 Октомври 2016 Доклад Share Публикувано 29 Октомври 2016 Всички коли ли имат въпросния сензор?Не съм забелязал при замърсен околен въздух клапата да се затваря. Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 30 Октомври 2016 Доклад Share Публикувано 30 Октомври 2016 Преди 11 часа, venomcorp написа: Добре де ако не е закачен или ако е лоша връзка няма ли да изписва друга грешка , а не - Defective ??? Имам някакви спомени, че май точно това изписваше. Трябва да изровя логове от колата си, от преди две години и половина. Тогава махах кората за да чистя дренажните отвори и бях забравил да го вквюча в буксата му. И май такава беше грешката. Ще проверя утре в архивът в работата. Преди 11 часа, joro09 написа: Всички коли ли имат въпросния сензор?Не съм забелязал при замърсен околен въздух клапата да се затваря. Всички 8Р го имат. Адрес на коментара Сподели в други сайтове More sharing options...
