ZankoBg Posted August 16, 2020 Report Share Posted August 16, 2020 Привет колеги някой може ли да ми каже какво тачно означава тази грешка , и колко точно е притеснителна . Friday,14,August,2020,06:58:06:29674 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 20.4.1.0 Data version: 20200421 DS317.0 www.Ross-Tech.com VIN: WAUZZZ8P19A136290 License Plate: 14.08.2020 Mileage: 167820km-104278mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8P-AU35 (1K0) Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77 VIN: WAUZZZ8P19A136290 Mileage: 167820km-104278miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb Part No SW: 8P7 907 115 L HW: 8P0 907 115 Q Component: 1.8l R4/4V TFSI 0030 Revision: AAH03--- Serial number: AUX7Z0I2FNV0XI Coding: 0103000C98070160 Shop #: WSC 06314 000 00000 VCID: 423A8C6952376C4D02-8016 7 Faults Found: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 162432 km Time Indication: 0 Date: 2020.04.13 Time: 11:31:48 Freeze Frame: RPM: 2774 /min Load: 89.4 % Speed: 100.0 km/h Temperature: 91.0C Temperature: 16.0C Absolute Pres.: 950.0 mbar Voltage: 14.351 V 006470 - Control Module 1 for Coolant Fan P1946 - 000 - Defective - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 167378 km Time Indication: 0 Date: 2020.08.07 Time: 14:18:35 Freeze Frame: RPM: 1175 /min Load: 22.0 % Speed: 34.0 km/h Temperature: 93.0C Temperature: 36.0C Absolute Pres.: 940.0 mbar Voltage: 14.097 V 049682 - Steering Column Control Module U0212 - 000 - No Communications - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Time Indication: 0 Date: 2047.15.31 Time: 31:63:63 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 72.0C Temperature: 36.0C Absolute Pres.: 940.0 mbar Voltage: 11.684 V 006472 - Control Module 2 for Cooling Fan P1948 - 000 - Output Short Circuit - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 167423 km Time Indication: 0 Date: 2020.08.07 Time: 16:45:53 Freeze Frame: RPM: 1512 /min Load: 10.2 % Speed: 66.0 km/h Temperature: 96.0C Temperature: 40.0C Absolute Pres.: 930.0 mbar Voltage: 13.970 V 006481 - Radiator Fan 2 (V177) P1951 - 000 - Movement Restricted / Jammed - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 167428 km Time Indication: 0 Date: 2020.08.07 Time: 16:51:20 Freeze Frame: RPM: 785 /min Load: 12.9 % Speed: 7.0 km/h Temperature: 90.0C Temperature: 42.0C Absolute Pres.: 930.0 mbar Voltage: 13.970 V 000369 - Fuel Trim; Bank 1 P0171 - 000 - System Too Lean - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 167793 km Time Indication: 0 Date: 2020.08.13 Time: 16:27:54 Freeze Frame: RPM: 932 /min Load: 12.2 % Speed: 14.0 km/h Temperature: 96.0C Temperature: 66.0C Absolute Pres.: 940.0 mbar Voltage: 13.843 V 001287 - Idle Control System RPM P0507 - 000 - Higher than Expected. - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 167824 km Time Indication: 0 Date: 2020.08.14 Time: 06:43:49 Freeze Frame: RPM: 917 /min Load: 9.4 % Speed: 0.0 km/h Temperature: 93.0C Temperature: 41.0C Absolute Pres.: 940.0 mbar Voltage: 13.970 V Качвам и целия лог. Log-14.08.2020-WAUZZZ8P19A136290-167820km-104278mi.txt Link to comment Share on other sites More sharing options...
ZankoBg Posted August 20, 2020 Author Report Share Posted August 20, 2020 @ZankoBg @bsdnikolov Link to comment Share on other sites More sharing options...
manoleo Posted August 20, 2020 Report Share Posted August 20, 2020 Грешките са доста. За някоя конкретна ли питаш или като цяло? Може би няма да е лошо да изтриеш всички грешки и за тези, които се появят отново, да отидеш в сервиз. Форумната диагностика често е подвеждаща. Link to comment Share on other sites More sharing options...
ZankoBg Posted August 20, 2020 Author Report Share Posted August 20, 2020 000665 - Boost Pressure Regulation P0299 за тази конкретно, тъй като се появиха на веднъж Link to comment Share on other sites More sharing options...
