allk Публикувано 10 Април 2008 Доклад Share Публикувано 10 Април 2008 Привет на всички!След закачане на въпросното ауди към компа се появиха следните грешки:VAG-COM Version: Release 311.2-NChassis Type: 4B - Audi A6 C5Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56Address 01 ------------------------------------------------------- Controller: 4B0 906 018 Component: 1.8L R4 5VT 0004 Coding: 04002 Shop #: WSC 000004 Faults Found:16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 35-10 - - - Intermittent18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent17956 - Boost Pressure Regulation Valve (N75): Open Circuit P1548 - 35-10 - - - Intermittent17834 - EVAP Purge Valve (N80): Open Circuit P1426 - 35-10 - - - IntermittentReadiness: 0000 0000Address 03 ------------------------------------------------------- Controller: 8E0 614 111 B Component: ABS/EDS 5.3 FRONT D00 Coding: 0273004283 Shop #: BB 24332No fault code found.Address 08 ------------------------------------------------------- Controller: 4B0 820 043 P Note: Excessive Comm ErrorsSkipping Address 15-AirbagsAddress 17 ------------------------------------------------------- Controller: 4B0 919 881 A Component: C5-KOMBIINSTR. VDO D15 Coding: 05142 Shop #: WSC 00000 IMMO-IDENTNR: AUZ7Z0W0823518 No fault code found.Address 35 ------------------------------------------------------- Controller: 4B0 962 258 E Component: Zentralverrieg.,DWA D32 Coding: 04683 Shop #: WSC 023251 Fault Found:01368 - Alarm triggered by Luggage Compartment Switch 35-00 - -Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 02325No fault code found.End -------------------------------------------------------Какво означава на кратко всичко това?След изчистване на грешките, колата започна да работи много нестабилно, да прекъсва като и подам газ, да забива муцуната иначе си пали нормално и поддържа стабилни обороти. Това продължи около 20км. , след което се оправи.Свързах я пак към компа и ми показа следната информация:VAG-COM Version: Release 311.2-NChassis Type: 4B - Audi A6 C5Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56Address 01 ------------------------------------------------------- Controller: 4B0 906 018 Component: 1.8L R4 5VT 0004 Coding: 04002 Shop #: WSC 00000No fault code found.Address 03 ------------------------------------------------------- Controller: 8E0 614 111 B Component: ABS/EDS 5.3 FRONT D00 Coding: 0273004283 Shop #: BB 24332No fault code found.Address 08 ------------------------------------------------------- Controller: 4B0 820 043 P Component: A6-Klimavollautomat D62 Coding: 00040 Shop #: WSC 02325 Note: Excessive Comm ErrorsSkipping Address 15-AirbagsAddress 17 ------------------------------------------------------- Controller: 4B0 919 881 A Component: C5-KOMBIINSTR. VDO D15 Coding: 05142 Shop #: WSC 00000 IMMO-IDENTNR: AUZ7Z0W0823518 No fault code found.Address 35 ------------------------------------------------------- Controller: 4B0 962 258 E Component: Zentralverrieg.,DWA D32 Coding: 04683 Shop #: WSC 02325No fault code found.Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 02325No fault code found.Address 56 ------------------------------------------------------- Controller: 4B0 035 152 Component: Radio 0001 Coding: 00205 Shop #: WSC 023253 Faults Found:00852 - Loudspeaker(s): Front 36-10 - Open Circuit - Intermittent00854 - Radio Display Output in dash Panel insert 49-10 - No Communications - Intermittent65535 - Internal Control Module Memory Error 00-00 - -End -------------------------------------------------------На какво може да се дължи това? Ако даден модул, а в случая ламбда сонда, N80 и N75 не функционират след 20км няма ли да натрупат грешка в борд компютъра пак?Благодаря! Адрес на коментара Сподели в други сайтове More sharing options...
VBI Публикувано 10 Април 2008 Доклад Share Публикувано 10 Април 2008 Вероятно някога на работещ двигател някой за проба е откачал куплунга на л-сондата, датчика N75 и т.н. Това е довело до записа на грешките. Щом не се появяват след изтриването им, според мен всичко ти е ОК. Просто може би при теб има период на адаптация на ЕКУ-то (което като функция го има и на по-старите ЕКУ-та) и затова е работила лошо първите 20км. Въпреки, че чак 20км за адаптация ми се виждат малко множко . Мога да ти дам пример с адаптирането на ЕКУ-то на механичен инжекцион при проблем с потенциометъра на дебитомера - в продължение на около 5мин. двигателя сам си вдига и сваля оборотите в диапазона 1000-3000, когато не е натиснат педала на газта и след това заспиват на 850. Това става след всяко запалване на двигателя ако въпросния потенциометър не е добре регулиран. Твоята кола е доста по-нова и може би заради това прави повече "check-ове" и е необходимо повече време за да се адаптира. Общо взето времето ще покаже - провери си след известно време грешките в ЕКУ-то. Ако няма, а и двигателя работи нормално значи всичко е ОК . Адрес на коментара Сподели в други сайтове More sharing options...
