sagiboy Публикувано 24 Септември 2014 Доклад Share Публикувано 24 Септември 2014 Здравейте, искам да попитам има ли кодировка която да пуска фаровете за мъгла с дневните светлини? Адрес на коментара Сподели в други сайтове More sharing options...
kainy Публикувано 24 Септември 2014 Доклад Share Публикувано 24 Септември 2014 Виж тук дали ще намериш нещо полезно:Daytime running lights behaviour: Daytime running lights (DRLs) behave differently in different markets, for example the front LED light strips that accompany Xenon lights turn off or dim in some markets when blinking/signalling. Aerodave on A5OC.com has researched this and posted his experiences here: http://www.a5oc.com/forums/showthread.php/have-solved-drl-2468/index.html. In short, he reports that changing Central Electronics 09, Submodule 0 (Master Cent. Elec. box, rather than a slave module), Byte 3 (fourth from the left), Bit 7 (first bit from the left in the binary representation, bottom check box in the VAG-COM long coding helper) is the key. If set to 1, setting it to 0 makes the DRLs stay on when signalling. Thanks to Aerodave and please see the full thread for more! Note: Depending on market certain light configurations may be illegal to drive on public roads.Aerodave - thanks! - sent this great list of additional bits you can toggle and turn to change the DRL behaviour.For submodule 0:Byte 02bit 0 - bit 1 - front side markers as DRLbit 2 - headlights as DRLbit 3 - fog lights as DRLbit 4 - LED strip as DRLbit 5 - bit 6 - side markers as DRLbit 7 - tail lights as DRLByte 03bit 0 - bit 1 - bit 2 - LEDs remain at full brightness with parking lightsbit 3 - bit 4 - Turns off DRLs when checkedbit 5 - bit 6 - bit 7 - Turn off LED-strip DRL with turn signal (dim LED if front side marker also selected as DRL)Byte 10bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)See also: http://www.a5oc.com/forums/showthread.php/some-new-lighting-3490/index.htmlApparently Ross-Tech have added long coding helper labels for A5 Central Electronics module in later versions of their VAG-COM/VCDS software. The downside of this seems to be that you can not easily edit bits unknown to the software, like the bits controlling some aspects of day-time running light behaviour (previously they just had checkboxes without labels for easy changing). If you need to change these bits using VAG-COM and you can't see the easy checkboxes in your version, you need to edit either the module coding binary representation or the bytes manually. Aerodave reporrts here http://www.a5oc.com/forums/showthread.php/help-vagcom-3585/index.html?p=39477 that you also need to hit tab, up or down after entering bits or byte manually in order to save them before exiting the long coding helper.If you choose to edit individual bytes, some instructions: When you need to change, say, bit 1 in Central Electronics submodule 0 byte 02 (front side markers as DRL) make note of the value displayed for byte 02 currently in the long coding helper. It is a byte displayed in hexadecimal numbers, ranging from 00 to FF (that is 0 to 255 in "regular" numbers, hex values just use letters A to F in addition to numbers). You will need to take the hex value of byte 02, convert it to binary representation, i.e. bit form (a byte consists of eight bits so the resulting "bit form" would be something like 10010001, eight zeros or ones), change the bit you want to change, and convert the bits back to a hex value that you can enter to the VAG-COM software in place of the old hex value.You can use e.g. this hexadecimal converter http://www.mathsisfun.com/binary-decimal-hexadecimal-converter.html or any other capable converter or calculator if you don't know exactly how to do the math yourself. In the linked converter, type the hexadecimal value from VAG-COM to the hex field and you can see the bits in the top-most binary field of the converter. Change the bits you like and note the resulting hex value. In bit math bits are entered from right to left, the right-most bit being the bit 0 and the left-most bit 7. So, if you need to change bit 1, change the second digit from the right. To change, say, bit 7, change the first digit from the left. After changing the bits in the calculator, you can enter the resulting hex value to VAG-COM to replace to existing hexadecimal byte value there.If bit math isn't your thing, apparently you could also remove the labels file for the particular module from the VAG-COM directory (Labels sub-directory) to be able to see and click the unlabeled bit checkboxes again. See here: http://www.a5oc.com/forums/showthread.php/help-vagcom-3585/index.html Адрес на коментара Сподели в други сайтове More sharing options...
sagiboy Публикувано 25 Септември 2014 Автор Доклад Share Публикувано 25 Септември 2014 Моята е преди фейса,ама надали има разлика за това? Адрес на коментара Сподели в други сайтове More sharing options...
baba Публикувано 25 Септември 2014 Доклад Share Публикувано 25 Септември 2014 Фейса са с лонг кодинг. Адрес на коментара Сподели в други сайтове More sharing options...
N1995 Публикувано 25 Септември 2014 Доклад Share Публикувано 25 Септември 2014 kainy 90% от нещата в тая страница са неприложими за нашите коли. Няма смисъл да си губи времето човек който е преди фейса или няма а5 Адрес на коментара Сподели в други сайтове More sharing options...
sagiboy Публикувано 25 Септември 2014 Автор Доклад Share Публикувано 25 Септември 2014 Усетих вече че няма да е това...но благодаря все пак Адрес на коментара Сподели в други сайтове More sharing options...
N1995 Публикувано 25 Септември 2014 Доклад Share Публикувано 25 Септември 2014 Иначе колега за да си пускаш фаровете за мъгла заедно с дневните трябва да си настроиш колата, че си в Канада. В кодинга на Central Electronics: 0xxxxx?: Country1 = Rest of World (RoW)2 = Northern European Countries (Sweden/Finland/Norway/Denmark)3 = USA4 = Canada Адрес на коментара Сподели в други сайтове More sharing options...
sagiboy Публикувано 25 Септември 2014 Автор Доклад Share Публикувано 25 Септември 2014 (Редактирано) Ще смени ли някои други настройки, освен фаровете?Цитиране на предходен пост! Редактирано 25 Септември 2014 от VBI Адрес на коментара Сподели в други сайтове More sharing options...
sagiboy Публикувано 25 Септември 2014 Автор Доклад Share Публикувано 25 Септември 2014 Нещо не мога да зацепя?!? това 0xxxxx? ли трябва да се вкара....абе някъде има ли инструкция Адрес на коментара Сподели в други сайтове More sharing options...
N1995 Публикувано 25 Септември 2014 Доклад Share Публикувано 25 Септември 2014 Няма как да правиш подобни промени по колата без да имаш елементарни познания за това какво е кодинг, адаптация и тн. Отвори сайта на Ross Tech и чети как работи VCDS и какво значи това, което съм ти дал. Относно първия ти въпрос - не съм запознат нещо друго освен поведението на светлините да се променя при тази кодировка. Адрес на коментара Сподели в други сайтове More sharing options...
mili 75 Публикувано 25 Септември 2014 Доклад Share Публикувано 25 Септември 2014 Нещо не мога да зацепя?!? това 0xxxxx? ли трябва да се вкара....абе някъде има ли инструкцияКолега в случая там където е въпросителната слагаш 4 за Канада, като влезеш да кодираш ще се ориентираш, не е някаква философия. Адрес на коментара Сподели в други сайтове More sharing options...
sagiboy Публикувано 26 Септември 2014 Автор Доклад Share Публикувано 26 Септември 2014 (Редактирано) Благодаря за отговора!Цитиране на предходен пост! Редактирано 26 Септември 2014 от VBI Адрес на коментара Сподели в други сайтове More sharing options...
