vivanet Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 Колеги , нуждая се от малко помощ при разчитане на грешките които даде при тест с ВагКом .Ето и лог файла , може ли да ми преведете каква грешка дава точно и на кой модул.Благодаря ви предварително....Chassis Type: 8E - Audi A4 B6/B7Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77VIN: WAUZZZ**********88 Mileage: 147600km/91714miles-------------------------------------------------------------------------------Address 01: Engine Labels: 059-907-401-AKE.lbl Part No: 8E0 907 401 D Component: 2.5L V6 TDI 0000SG 0014 Coding: 02015 Shop #: WSC 00945 VCID: 2647F2AB62B Part No: 00000059 Component: 130 106LC150_1.V79346340991 WAUZZZ8E33A248417 AUZ6Z0B03474822 Faults Found:17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - -17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - -Readiness: N/A-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04455 Shop #: WSC 06435 VCID: 2647F2AB62BNo fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 K Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 VCID: 295DF9977355 Faults Found:01809 - Actuating Motor for Temperature Flap; Left (V158) 41-10 - Blocked or No Voltage - Intermittent01810 - Actuating Motor for Temperature Flap; Right (V159) 41-10 - Blocked or No Voltage - Intermittent01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-00 - Open or Short to Plus00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00011 Shop #: WSC 00000 VCID: 346318E3A47No fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 00000 000 00000 VCID: 3E773ACB9AB1 Fault Found:01739 - Crash Sensor for Front Airbag; Pass. Side (G284) 011 - Open Circuit - MIL ON-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksбulenmodul 0308 Coding: 00012 Shop #: WSC 63351 VCID: 366722EBB2BNo fault code found.-------------------------------------------------------------------------------Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 K Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 01100 Shop #: WSC 00945 VCID: 2C5300837C7 WAUZZZ8E33A248417 AUZ6Z0B03474822 Faults Found:00562 - Sensor for Oil Level/Temperature (G266) 30-00 - Open or Short to Plus01304 - Radio 49-00 - No Communications-------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 AT Component: Komfortgerбt T23 1210 Coding: 06976 Shop #: WSC 63351 VCID: 83010B3F319 Part No: 8E1959801 Component: Tхrsteuer.FS BRM 0002 Part No: 8E1959802E Component: Tхrsteuer.BF BRM 0002 Part No: 8E0959801A Component: Tхrsteuer.HL BRM 0002 Part No: 8E0959802A Component: Tхrsteuer.HR BRM 0002 10 Faults Found:00956 - Key 2 35-10 - - - Intermittent01331 - Door Control Module; Driver Side (J386) 80-00 - Single-Wire Operation01802 - Door Warning Lamp; Pass Side (W36) 57-10 - Electric Circuit Failure - Intermittent01332 - Door Control Module; Passenger Side (J387) 80-10 - Single-Wire Operation - Intermittent01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent01803 - Door Warning Lamp; Rear Left (W37) 57-10 - Electric Circuit Failure - Intermittent01333 - Door Control Module; Rear Left (J388) 80-10 - Single-Wire Operation - Intermittent01804 - Door Warning Lamp; Rear Right (W38) 57-10 - Electric Circuit Failure - Intermittent01334 - Door Control Module; Rear Right (J389) 80-10 - Single-Wire Operation - Intermittent00935 - Electric Window Motor; Rear Right (V27) 62-10 - No or Incorrect Adjustment - Intermittent-------------------------------------------------------------------------------Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00060 Shop #: WSC 63351 VCID: 04038823B473 Faults Found:01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49) 30-00 - Open or Short to Plus01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48) 30-00 - Open or Short to Plus00776 - Level Control System Sensor; Left Front (G78) 31-00 - Open or Short to Ground Адрес на коментара Сподели в други сайтове More sharing options...
Todir Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 Малииии Като ги изтриеш пак ли се появяват?Така като гледам почти всичко е за проблеми с връзката. Да не си я наводнявал тая кола? Адрес на коментара Сподели в други сайтове More sharing options...
vivanet Публикувано 21 Април 2012 Автор Доклад Share Публикувано 21 Април 2012 Не съм я наводнявал ... имам проблем с централното заключване в общи линии тук заключва от дистанционното ту не ... проблема с еърбега го оправих оказа се скъсан кабел на буксата точно до преден десен фар за датчика на еърбега ... но другите грещки остават Адрес на коментара Сподели в други сайтове More sharing options...
Ivo_Dinkov Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 От лявата страна ако е творил някой незнаен майстор, може да е наранил кабелен сноп.Разглабяне и оглеждане е решението. Адрес на коментара Сподели в други сайтове More sharing options...
buzzi Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 (Редактирано) На ксенона не ти работи моторче и предния новомат,изобщо както те посъветва ИВО,някъде според мен губиш маса Редактирано 21 Април 2012 от buzzi Адрес на коментара Сподели в други сайтове More sharing options...
vivanet Публикувано 21 Април 2012 Автор Доклад Share Публикувано 21 Април 2012 На ксенона проблема е другаде ... фара е сменян не е оригиналния тъй като колата е имала удар отдясно и неюо не е вързано както трябва иначе моторчето си го има във фара. Мен ме интересува най вече показанията за датчик за температурата на маслото и централното заключване Адрес на коментара Сподели в други сайтове More sharing options...
Ivo_Dinkov Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 Давам пример- юнаците от ЕТ ровили във вратите на Фабията ми. Извадили някой друг кабел на централното, ама не ги включили правилно и що да видят- цъкат като луди машинките и се отключва и заключва постоянно колата. Хоп- изключили управлението на предните и ги бандажирали 'на богато' с изолибанд(3М при това!).И аз стоя и се чудя какво е изгоряло, даже цяло ново центрлно купих. Докато Ваското1 не откри 'творението'.Пак ти казвам, щом е имало намеса и на бояджия- разглобявай задължително прагове и пластмаси и проследи сноповете. Адрес на коментара Сподели в други сайтове More sharing options...
werti Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 Добре де тая кола изобщо пали ли? Изписва,че паленето е блокирано от имобилайзера. Адрес на коментара Сподели в други сайтове More sharing options...
Todir Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 Датчика за налягане на маслото трябва да го погледнеш да не се е откачил, скъсала жичка или окислила буксата. Нямам си идея къде е наврян на 2.5тди. Също така трябва да обърнеш внимание на грешката за имобилайзера. Явно понякога не ти разчита ключа. Адрес на коментара Сподели в други сайтове More sharing options...
vivanet Публикувано 21 Април 2012 Автор Доклад Share Публикувано 21 Април 2012 Проблем с паленето нямам никакъв и колата никога не ми е гаснала .... откъде се измъдриха тези грешки с имобилайзера незнам ако има проблем с него изобщо няма да запали а тя си пали от раз. Другото интересно като проблем е , че от 2 седмици насам двигателя почна да тресе яко все едно някой клапан не работи , последния път като сменях маслото и имаше в картера 2 пулчета паднали ... скоро май ще отварям двигателя Адрес на коментара Сподели в други сайтове More sharing options...
Bobu Публикувано 21 Април 2012 Доклад Share Публикувано 21 Април 2012 Не съм я наводнявал ... имам проблем с централното заключване в общи линии тук заключва от дистанционното ту не пробвай няколко дни с резервното, дали го прави Адрес на коментара Сподели в други сайтове More sharing options...
kyky1 Публикувано 31 Май 2012 Доклад Share Публикувано 31 Май 2012 vivanet оправи ли проблемапри мен е по-лошо но започна като при тебмодула спря напълнокато вдигнах тапицерията на пода имаше 20-30 литра водамодула плуваше като във ванасваляй му веднага бушона ако продължава да губи връзка и проверявай за влага 24 бушон епод седалката има датчик - може да бръкнеш с пръсти покрай него дали има влага по тапицерията49-10 - No Communications - Intermittent01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent01336 - Data Bus for Comfort System 37-10 - Faulty - Intermittent13 Faults Found:01176 - Key 07-10 - Signal too Low - Intermittent00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent00457 - Control Module for Network (J519) 49-10 - No Communications - Intermittent01330 - Central Control Module for Central Convenience (J393) 49-00 - No Communications01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent01332 - Door Control Module; Passenger Side (J387) 49-10 - No Communications - Intermittent01334 - Door Control Module; Rear Right (J389) 49-00 - No Communications Адрес на коментара Сподели в други сайтове More sharing options...
sdsuzuki Публикувано 1 Юни 2012 Доклад Share Публикувано 1 Юни 2012 Много често се събира вода в отделението под чистачките,запушват се отводнителните мотори и от там влиза в купето под мокета и напоява много сериозно ватата под него а както всички знаем конфотрт с-та е под шофьорската страна и от тама се получават тези аномалий,др. вариант е хлабава клема на масата на акумолатора или напрежение в него под 12,3v също трупа доста грешчци забравих скоро наистина ще правиш кобилици и валове щом имаш паднали пулчета,тресенето ти е от клапаните Адрес на коментара Сподели в други сайтове More sharing options...
