Темпомат (Cruise control) A4 B6
stilko
Friday,18,March,2016,12:19:48:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8EX5A023060   License Plate:
Mileage: 164750km-102370mi   Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
VIN: WAUZZZ8EX5A023060   Mileage: 164750km/102370miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC G000SG  5934
   Coding: 00002
   Shop #: WSC 63251
   VCID: 6ADB2423168A324E2A7-49D8
   WAUZZZ8EX5A023060     AUZ6Z0D0180313
2 Faults Found:
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
19586 - EGR System
            P3130 - 35-10 - Regulation Range Exceeded - Intermittent
Readiness: 0 1 0 0 0
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       4529
   Coding: 00000
   Shop #: WSC 00000
   VCID: E5C1D71F7F949D36875-5072
2 Faults Found:
01044 - Control Module Incorrectly Coded
            35-00 - -
00778 - Steering Angle Sensor (G85)
            66-10 - Not Matched - Intermittent
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1424
   Coding: 00000
   Shop #: WSC 63251
   VCID: 60CF460BE0B6781EF43-5072
No fault code found.
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0606
   Coding: 00001
   Shop #: WSC 63251
   VCID: 326BFC43FEDABA8E527-4A3A
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 J
   Component: Airbag 8.4EP        1002
   Coding: 0010602
   Shop #: WSC 63251 000 00000
   VCID: 3E73D8736A826EEEA6F-5000
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
            001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 N
   Component: Lenksбulenmodul     0611
   Coding: 00042
   Shop #: WSC 12345
   VCID: 3E73D8733A826EEEA6F-4A9C
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 900 M
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 00001
   Shop #: WSC 44314
   VCID: 2E53E833EAE29E6E36F-5072
2 Faults Found:
01316 - ABS Control Module
            49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 AS
   Component: Komfortgerбt T01    1412
   Coding: 06976
   Shop #: WSC 63251
   VCID: 820BEC838EFA4A0E027-4A3A
   Subsystem 1 - Part No: 8E1959801B
   Component: Tхrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802B
   Component: Tхrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tхrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tхrsteuer.HR BRM 0205
4 Faults Found:
00956 - Key 2
            35-10 - - - Intermittent
01559 - Drivers Door
            59-10 - Can't Unlock - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
            27-10 - Implausible Signal - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
            62-10 - No or Incorrect Adjustment - Intermittent
End   ---------------------------------------------------------------------
Не виждам нищо нередно (освен грешките). Пробва ли да активираш CCS функционалността на двигателя с кодът 11463. А също така, провери ли дали имаш къбелът от Engine ECU-то до  Steering wheel.
Редактирано от bsdnikolov
проблемът е ABS с него не мога да се оправя круиз контролът и борд комютърът са ОК не мога да настроя сензора на волана и съответно ABS. работата май отива на сервиз само,че не нам кой?
Редактирано от m_nanchev
Ахаааа. Вече те разбрах.
ABS-ът беше голяма мъка. Първо се задаваше "оборудването", а после и кодирането. Последния ми сблъсък с това не бе приятен. С моя кабел отказваше да го направи и като взех на приятел неговия кабел, всичко мина от раз.
Пробвах с 3 кабела на три различни компа с 3 различни версии на Vag-com резултатът е един и същ.Всички стоиности освен ABS мога да ги променям сензора на волана и abs си остават проблем някави идеи ?
Спазваш ли процедурата. Преди да ти позволи да прекодираш модулът, трябва да го впишеш:
Login
Note #1: After Login has been carried out you need to recode the control module.
Note #2: Special Login 07499 is used for 6-Cylinder Diesel Engine with 1LG Brakes and Multitronic.
Note #3: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
0?xxx: Chassis
9 = Audi A4
0x?xx: Brakes
2 = Brembo 17" (PR-1LJ)
3 = FN3 16" (PR-1LT/1LF)
4 = HP2 16" (PR-1LX)
4 = FNR 16" (PR-1LA/1LG)
5 = FN3 15" (PR-1LB/1LE)
6 = C54 (PR-1LZ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8 Cyl. Gasoline
0xxx?: Transmission
5 = Manual
7 = Automatic (5HP19, 5HP24, AG4, AG5)
9 = Multitronic (01J, CVT)
Coding
Note #1: Coding is accepted after a specific login has been carried out.
Note #2: After successful coding the steering angle sensor basic setting needs to be carried out within the same diagnostic session.
Note #3: Special Coding 04499 is used for BFB Engine with 1LT Brakes and Multitronic.
Note #4: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
Note #5: In some cases, you will need to enter a non-zero WorkShop Code, such as 12345.
0?xxx: Chassis
4 = Audi A4
0x?xx: Brakes
1 = C54 (PR-1LZ)
2 = FN3 15" (PR-1LB/1LE)
3 = HP2 16" (PR-1LX)
3 = FNR 16" (PR-1LA/1LG)
4 = FN3 16" (PR-1LT/1LF)
5 = Brembo 17" (PR-1LJ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
0xxx?: Transmission
5 = Manual
Basic Setting
Steering Angle Sensor (G85) Calibration
Before starting the procedure turn the steering wheel at least 30 ° left and back straight ahead.
[Meas. Blocks - 08]
Group 005 Field 1 (Steering Angle Sensor -G85-)
Specification: 0.0 °
Tolerance (when straight): ±5.0 °
[Done, Go Back]
[Login - 11]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 001
[Go!]
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
Благодаря на всички проблемът е решен всички лампи изгаснаха!
Да го бях прочел !!!
Special Notes
  • Some of the Bosch 5.7 modules will not show live Steering Angle Sensor (G85) readings after the Login and Coding are performed. If this is the case -2.5 ° may be stuck in Measuring Block 005 and will not change when the wheel is turned. Make the wheels as straight as possible and continue with the Steering Angle Sensor (G85) Calibration.
  • After doing the G85 Calibration, you may get a 01486 - System Function Test Active, this is normal. Please see 01486.
и буквално изпълнение на инструкциите .
  • 3 weeks later...
Здравейте колеги карам ауди А4 Б6 1,9тди. Днес проверих модула на волана и се оказа че не поддържа темпомат. Някой може ли да ми препоръча сервиз в Стара Загора или региона където могат да ми го монтират, понеже ще се наложи да се пускат кабели от ЕКУ-то към модула и ме е страх да го правя аз.
On 16.01.2011 г. at 9:59 AM, Данаил Петров said:
Здравейте,
искам само да допиша няколко неща, за да е пълна темата.
Благодаря на колегата Райно, който ми продаде модула на доста добра цена. Модулът беше свален от B7, така че и това е хубаво да се знае, че е възможно да се ползва такъв от B7.
При мен монтажа и адаптацията беше извъшрен в един автосервиз, който препоръчвам с 2 ръце - Винаров АВТО (Александър Винаров). Искам да отбележа, че НЕ СЕ наложи да изпълняваме стъпките от 17 до 20, а именно:
Имаше въпроси относно разликите в модулите. Бях пуснал линк към Wiki-то на ross-tech, но за хората, които не се справят с английския ще се опитам да обобщя накратко:
Има три типа контролни модули, два от които поддържат опцията Cruise control:
Lowline
Поддръжка на волан: Стандартен Волан (4-лъча)
Поддържани опции: Trip Computer (ТЕЗИ МОДЕЛИ НЕ ПОДДЪРЖАТ Cruise Control!)
Part Numbers: 8E0-953-549-F 8E0-953-549-S
Midline
Поддръжка на волан: Стандартен Волан (4-лъча), Стандартен Волан (3-лъча), Мултифункционален Волан (4-лъча)
Поддържани опции: Trip Computer, Cruise Control
Part Numbers: 8E0-953-549-L, 8E0-953-549-N
Highline
Поддръжка на волан: тандартен Волан (4-лъча), Стандартен Волан (3-лъча), Мултифункционален Волан (4-лъча
Поддържани опцииs: Trip Computer, Cruise Control, Steering Wheel Heating
Part Numbers: 8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R
Ами това е, смятам, че темата вече е завършена/изчерпана, и може би е добра идея да бъде заключена :hilezh:
Поздрави!
да разбирам че ако моя модул е един от следните :
8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R 8E0-953-549-L, 8E0-953-549-N
ще мога да включа лост за автопилот и лост за борд.компютър ?
Защо не четете  бе хора, писано е хиляда пъти вече...
ВСИЧКИ модули имат възможност за бордови комп. Сменя се ръчката и се активира.
САМО модулите с букви РАЗЛИЧНИ  от F и S имат функция Темпомат!
На Sunday, April 10, 2016 at 22:39, Стилян написа:
Първо провери дали има кабел на пин 5 на буксата на модул!  Ако го има - няма какво да прекарваш!
Само подмяна и активиране, адаптиране и т.н.
Редактирано от Pav3l
Преди 5 часа, Pav3l написа:
Цитиране на предходно мнение!
Може ли да се види само със сваляне кората на волана?
Точно този кабел трябва да е.
Модула е труден. Лост се намира и нов, макар и китаец, на добра цена.
А ако с модула намериш и долната кора ще е оше по-добре.! Иначе ще трябва да режеш твоята.
Намерих модул с лост за 130лв. Днес успях да го монтирам, нямах никакви проблеми с кодирането всичко работи перфектно. :):) Благодаря на колегата Pav3l за помоща.
здравейте, поизчетох темата и се запознах с повечето неща.Но както при всеки ми изникнаха някой въпроси и се надявам да ми съдействате :)
колата е Б6 2004 1.9 131 (няма нито бордови нито темпомат) :(
Купих си правилния модул със лост + един лост за чистачки с бордови компютър + кора общо взето имам всичко нужно.
В моят случай да разбирам ли че този кабел го нямам и трябва да го пускам? :(
Проверете дали имате кабел на 5-ти пин на черната букса за модула на кормилната колона. Трябва да е в цвят СИН+ЗЕЛЕН. Ако имате пропуснете следващите точки до точка 21.
Благодаря предварително
Фил
Трябва да провериш може и да го имаш. Аз предварително проверих като свалих само кората, ако имаш син кабел със зелена линия на буксата която влиза в модула ще стане по лесния начин, ако го няма по-добре отивай в сервиз да ти го монтират . :) Определено екстрата си заслужаша !!!
Да видим дали съм разбрал правилно. Смъквам долната чат на кората, която се маха с 3 болтчета и гледам за въпросният кабел ако го има го има ако го няма шок и ужасТ :(
П.С. тази букса се намира някъде в долната част на модула нали ?
Редактирано от fstanev9
