Bobu Публикувано 4 Април 2010 Доклад Share Публикувано 4 Април 2010 Колата е а4, б6, 1.9тди, 131 коня.Понеже не е в София, си занесох лаптопа и пуснах една диагностика на Ваг ком и излезнаха следните неща, може ли някой да каже какво _точно_ представляват, фатални и трудно отстраними ли са? VAG-COM Version: Release 409.1-S-------------------------------------------------------------------------------Address 01: Engine2 Faults Found:17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus P1256 - 35-10 - - - Intermittent17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus P1586 - 35-10 - - - IntermittentReadiness: N/A-------------------------------------------------------------------------------Address 08: Auto HVAC Controller: 8E0 820 043 H Component: A4 Klimaautomat 1016 Coding: 00000 Shop #: WSC 633513 Faults Found:00710 - Defroster Flap Positioning Motor (V107) 41-00 - Blocked or No Voltage01809 - Actuating Motor for Temperature Flap: Left (V158) 41-10 - Blocked or No Voltage - Intermittent01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent-------------------------------------------------------------------------------Address 46: Central Conv. Controller: 8E0 959 433 AR Component: Komfortgerat T85 1310 Coding: 06720 Shop #: WSC 633516 Faults Found:01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent00955 - Key 1 35-10 - - - Intermittent00956 - Key 2 35-10 - - - Intermittent-------------------------------------------------------------------------------Address 56: Radio Controller: 8E0 035 152 Component: chorus II GRO 0008 Coding: 01000 Shop #: WSC 633511 Fault Found:01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent Адрес на коментара Сподели в други сайтове More sharing options...
Raino Публикувано 4 Април 2010 Доклад Share Публикувано 4 Април 2010 Това ,което мога аз да кажа е,че виждам температурен датчик за смяна(струва 20тина лева.) , клапите на климатроника са се разадаптирали(характерно за Б6 когато не се сменя често поленовия филтър). Има проблем в комфорт модула защото не си отваря вратите и си забравя ключовете.Нека някой по-компетентен да се изкаже. Адрес на коментара Сподели в други сайтове More sharing options...
Dido1234 Публикувано 4 Април 2010 Доклад Share Публикувано 4 Април 2010 ми доколкото виждам... едната ти е за радиото - не е фатална(ако си с навигация ММИ или РНС-е си ъпдейтни софт-а и няма да имаш проблеми занапред)за другите не мога да ти кажа нищо освен за какво са:за климатроникатемпературен датчик за другото не съм сигурен, но поне от това което чета става въпрос за централното. Адрес на коментара Сподели в други сайтове More sharing options...
Bobu Публикувано 4 Април 2010 Автор Доклад Share Публикувано 4 Април 2010 Raino, Dido, мерси )други мнения Адрес на коментара Сподели в други сайтове More sharing options...
ru6 Публикувано 4 Април 2010 Доклад Share Публикувано 4 Април 2010 Виждам ,че тези грешки са временни ( Intermittent ) . Пробвай да ги изтриеш и пак провери! Адрес на коментара Сподели в други сайтове More sharing options...
Ivanu6ka Публикувано 4 Април 2010 Доклад Share Публикувано 4 Април 2010 Имаш грешки в климатроника, централното и радиото. По двигателя са датчика за температура на антифриза и някакъв соленоидна клапа. И аз не съм наясно за коя точно иде реч, че в колата има поне няколко соленоидни клапи. Грешките са доста(12) и в различни модули, но е възможно да са се получили от слаб акумулатор. Пробвай да ги изчистиш и виж след това дали висят още някои. Това за температурния сензор май си е често явление...и при мен я имаше и смених датчика(40 лв). Другите ако се появят и след изчистване...не знам какво да те посъветвам, дали сам да мъчиш или на сервиз, но това ти ще си прецениш. Адрес на коментара Сподели в други сайтове More sharing options...
M Публикувано 5 Април 2010 Доклад Share Публикувано 5 Април 2010 температурен датчик.. не слагай такъв от 20лв, щото не карат дълго, на 1.9TDI не се сещам къде е, ама на 1.8Т е заврян на ма**а си в ***** и не ми е интересно да се налага да се сменя през 5-10 000км. Оригиналния е около 60-70лв, но си струва парите. Иначе проблема не е рядко срещан, около 200 000км се проявява.. естествено много зависи от късмета и експлоатацията.другата "грешка" по мотора е за тампон на мотора. Нали искате хем да е дизел хем да не клати купето и затова от Ауди са се погрижили, залага на левия тампон - около 200лв ОЕ, сменя се що-годе лесно.за климатика - надали да се оправи с триене на грешки, или с "калибрирани" или с каквото и да било.. просто блокират клапите, горят моторчета и т.н... пак се случва около 200 000км, но не го приемай като твърда гарница - въпрос на експлоатация и поддръжка и късмет - може и по-рано, може и по-късно да сдиплят.. работата ми се струва доста, като цени незнам.това за комфорт модула - незнам да ти кажа от какво се е получило, но си мисля след триене трябва да не се появяват пак. Адрес на коментара Сподели в други сайтове More sharing options...
Raino Публикувано 5 Април 2010 Доклад Share Публикувано 5 Април 2010 Датчика наистина не е 20лв. .Аз сложих оригинален и сега погледнах,че с отстъпката ми е към 50лв. Адрес на коментара Сподели в други сайтове More sharing options...
