Tsanko89 Публикувано 7 Септември 2023 Доклад Share Публикувано 7 Септември 2023 В момента е 0004031 промених го на 0004858 започна да показва течноста но пък колана е само визоялно и звуково за 6 сек.Изпратено от моят 2210129SG с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 8 Септември 2023 Автор Доклад Share Публикувано 8 Септември 2023 Ето ти нагледно, как се прави (променя) кодировката. Instrument Cluster Coding: 00??xxx: Equipment +01 = 2nd Fuel Tank Characteristic (All-Wheel Drive) +02 = Highline without DIS (for Midline variant 9Q3 - Automatic without DIS) +04 = Manual Transmission (not midline variant 9Q3) +08 = 2nd tire circumference pair (e.g. winter tires) +32 = AFS (Advanced Front Lighting System (cornering lights) 00xx?xx: Country 0 = Germany 1 = Rest of World (RoW - Left Hand Steering) 2 = USA / 3 = Canada 4 = Great Britain (Right Hand Steering) 5 = Japan (Left Hand Steering) 6 = Arabien States 7 = Australia 8 = Rest of World (RoW - Right Hand Steering) 9 = Japan (Right Hand Steering) 00xxx?x: Seat Belt Warning 0 - No Seat Belt Warning 1 = Europe-NCAP (permanent visual warning and acoustic warning active for 91 seconds) 2 = USA and Canada OLD (visual and acoustic warning for 6 seconds) 3 = USA and Canada NAR-NEW (permanent visual warning and acoustic warning active every 30 seconds) 4 = Europe-NCAP (including passenger - permanent visual warning and acoustic warning active for 91 seconds) 5 = USA and Canada OLD (including passenger - visual and acoustic warning for 6 seconds) 6 = USA and Canada NAR-NEW (including passenger - permanent visual warning and acoustic warning active every 30 seconds) 00xxxxxx?: Illumination & Washer Fluid Warning 0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF) 1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF) 2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF) 3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF & 2nd Dimming Characteristic) 4 = Needles ON and Scales ON (Term. 15 OFF / Term. 58 OFF) +5 = Washer Fluid Warning active Ти в момента си го направил на: 0004858 ==> 0004858 ==> Equipment: Manual Transmission (not midline variant 9Q3) 0004858 ==> Country: Rest of World (RoW - Right Hand Steering) 0004858 ==> Seat Belt Warning: USA and Canada OLD (including passenger - visual and acoustic warning for 6 seconds) 0004858 ==> Illumination & Washer Fluid Warning: Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF & 2nd Dimming Characteristic) +5 = Washer Fluid Warning active Предполагам, вече хващаш принципа на промяна на кодировката. Оправи си я. Най-вече си оправи 0004858. Предполагам колата ти не е с десен волан. Според мен, правилната ти кодировка, с активно предупреждение за шофьорски и пасажерски колан, ляв волан, при контакт да светят само стрелките и да имаш предупреждение за течността за чистачките, трябва да бъде 0004146. Адрес на коментара Сподели в други сайтове More sharing options...
Tsanko89 Публикувано 8 Септември 2023 Доклад Share Публикувано 8 Септември 2023 Благодаря много ще изпробвам и ще пиша за резултати,а за централ електрик модула можеш ли да ми дадеш отговор дали имам място за фароме за мъгла.Това му е номера на снимката горе видях линка кадето си постнал с номерата видях че се води hight неси спомням колко бита.Изпратено от моят 2210129SG с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
bsdnikolov Публикувано 8 Септември 2023 Автор Доклад Share Публикувано 8 Септември 2023 Преди 4 часа, Tsanko89 написа: дали имам място за фароме за мъгла. Не те разбирав. В какъв смисъл? Ако иимаш предвид, че в момента нямаш предни фарове за мъгла и искаш да си поставиш, то тогава отговорът ми е "да". Ще са ти нужни: фаровете за мъгла капаците около фаровете ключ за фарове, с функция предни фарове за мъгла 1,5 кв. кабели от модула до фаровете (приблизително около 5-6 метра) два пина с номер A 013 545 78 26 за централ електрик модула буксите с пиновете към двата фара кабел 0,35 кв за от модула до ключа за фарове два пина с номер 12 52 7 510 672 за кабела от модула до ключа за фарове Адрес на коментара Сподели в други сайтове More sharing options...
Tsanko89 Публикувано 8 Септември 2023 Доклад Share Публикувано 8 Септември 2023 Благодаря за подробната информация значи само кабелите и пиновете трябва да намеря защото фаровете си ги има с капаците ключ също си взех на сгодна цена и то този които е с бутона за изпратиме до вкъщи.Изпратено от моят 2210129SG с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
Tsanko89 Публикувано 9 Септември 2023 Доклад Share Публикувано 9 Септември 2023 Според мен, правилната ти кодировка, с активно предупреждение за шофьорски и пасажерски колан, ляв волан, при контакт да светят само стрелките и да имаш предупреждение за течността за чистачките, трябва да бъде 0004146.0004146 с този код ми дава грешка ето и снимка какво ми изписваИзпратено от моят 2210129SG с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
Tsanko89 Публикувано 9 Септември 2023 Доклад Share Публикувано 9 Септември 2023 0004537 Този сложих поне да е с ляв волан само остава да пробвам за течноста дали ще работи мисля че трябва но ще проличиИзпратено от моят 2210129SG с помощта на Tapatalk Адрес на коментара Сподели в други сайтове More sharing options...
Dumperbg Публикувано 22 Септември 2023 Доклад Share Публикувано 22 Септември 2023 Здравейте, на ауди А3 МГ2009 си направих различните output tests с VCDS, всичко е ок, но искам да попитам дали има подобен начин да се тестват и съобщения и индикации, които се извеждат на FIS-дисплея (изгоряла крушка, ниво на течност за чистачките, проблем с дпф и т.н? Благодаря. Адрес на коментара Сподели в други сайтове More sharing options...
