sky Публикувано 18 Октомври 2011 Доклад Share Публикувано 18 Октомври 2011 Има ги за 2009 с модел W440. Дават ги много добри. Адрес на коментара Сподели в други сайтове More sharing options...
exstasy Публикувано 18 Октомври 2011 Доклад Share Публикувано 18 Октомври 2011 Hankook i*cept Evo"I was looking for a tire with a proper shoulder on it for dry handling, while still being decent in snow. The price for the W.Drives were substantially higher, so I decided to go with the Hankooks.Dry Impressions:So far, the total cornering grip appears to be simular to my old AVS. Once committed to a turn, the break away is very predictable. On proper suspension, you get like 80% of the total grip of a summer tire of simular size.Wet Impressions:In the poring rain or damp mornings, the amount of grip is much better than any all season. The level of cornering grip is noticeably and predictably less as it gets more wet, but the braking grip appears closed to unchanged regardless of wetness.Cold/Warm Impressions:So far, no temperature change appears to affect it.Handling Feel Impressions:One of the advertised features of this tire is a different rubber compound on the inside than the outside. The inside is supposed to be harder to last longer, with the outside softer for more grip. Driving on your wits or impulse, you don't notice it too much, but if you really take note, there is a weird rubbery feeling upon initial steering input. Its almost like you can jiggle the tires around a tiny bit with nothing happening, it reminds me of all seasons. Once any load is exerted on the tire, the softer portion grabs and there is quick feedback and lots of grip.A consequence of this, which I discovered quickly: if you exert extreme yaw (jink the wheel hard), the back tires can break loose if they are not loaded properly. This meant I can do power sliding u-turns in the dry. It also means I can setup 4 wheel drifts, by overloading the rear tires briefly just before a medium turn. If you've ever driven a RWD car on balding tires with lots of camber, its exactly the same; in RWD, you can spin them up pretty easy, but once loaded in a corner they have plenty of grip.Snow impressions:Light snow and slush. The acceleration grip is just remarkable on pure snow (prolly just the larger width), but the deceleration and horizontal grip is the same as other snow tires I've tried. The slush/standing water handling is remarkable, I hit a huge puddle and the sound scared me because there was no feedback in the wheel or loss of traction. It was completely stable."От: http://forums.nasioc.com Адрес на коментара Сподели в други сайтове More sharing options...
asenovb Публикувано 18 Октомври 2011 Автор Доклад Share Публикувано 18 Октомври 2011 Има ги за 2009 с модел W440. Дават ги много добри.Но в теста за 2011/12 ги няма, а и в миналия май ги нямаше. Адрес на коментара Сподели в други сайтове More sharing options...
sky Публикувано 19 Октомври 2011 Доклад Share Публикувано 19 Октомври 2011 (Редактирано) Поръчах си Ханкок-а. Като дойде ще споделям. Редактирано 19 Октомври 2011 от sky Адрес на коментара Сподели в други сайтове More sharing options...
audiceco Публикувано 19 Октомври 2011 Доклад Share Публикувано 19 Октомври 2011 Излезе теста на зимните гуми сезон 2011-2012 година проведен е с размер на гумите 195/65/15 за повече информация четете ТУК Адрес на коментара Сподели в други сайтове More sharing options...
AALEXANDROV Публикувано 21 Октомври 2011 Доклад Share Публикувано 21 Октомври 2011 Излезе теста на зимните гуми сезон 2011-2012 година проведен е с размер на гумите 195/65/15 за повече информация четете ТУКПише пак за Контито, че са най-добри.Само леко не съм съгласен Семперита да е по-добър от Дънлоп и Мишлен, но знае ли човек? Адрес на коментара Сподели в други сайтове More sharing options...
dOomEd Публикувано 22 Октомври 2011 Доклад Share Публикувано 22 Октомври 2011 Здравей колега. Вчера сложих Michelin Alpin A4 най новите .. много съм доволен от тях.. Адрес на коментара Сподели в други сайтове More sharing options...
drob4o Публикувано 22 Октомври 2011 Доклад Share Публикувано 22 Октомври 2011 как разбра колега? на сняг и мокро пробва ли ги? Адрес на коментара Сподели в други сайтове More sharing options...
SLO Публикувано 25 Октомври 2011 Доклад Share Публикувано 25 Октомври 2011 Тестовете се прават с чисто нови гуми и никаде не се споменава за поведението им след 10к км да речем.Та от тук идват добрите резултати на разни Корейски и други по-малко известни марки и модели гуми.Аз имам впечатление от Кумхо,купих ги чисто нови,сложих ги и бях въодушевен от поведението им.Така до първите няколко хил.км.След като се поизтърка горния слой,поведенито се промени драстично.Според мен,"марковите" гуми си заслужават парите.Аз преди 3-4 дни сложих 4бр. новички Dunlop Wintersport 3D. Адрес на коментара Сподели в други сайтове More sharing options...
milen_sl Публикувано 25 Октомври 2011 Доклад Share Публикувано 25 Октомври 2011 http://www.peter.and.bilyana.net/index.php/2011/10/20/nay-dobrite-zimni-gumi-za-20112012/ Адрес на коментара Сподели в други сайтове More sharing options...
sky Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 (Редактирано) Аз сложих на форда Дънлоп 4Д. На аудито съм с Мишелин ПА3 вече втора година и съм доволен от него. На магистралата с 210 не го усети. Много добра гума. Редактирано 26 Октомври 2011 от sky Адрес на коментара Сподели в други сайтове More sharing options...
nmm Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 ти с 210 караше в снега, или направи някаква екстремна маневра, какво значи не го усети?? Адрес на коментара Сподели в други сайтове More sharing options...
SpeedyMan Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 Контито си държи и след няколко години, някак си смеската остава "адекватна". Предполагам, че и с другите марки от този клас е така. Адрес на коментара Сподели в други сайтове More sharing options...
asenovb Публикувано 26 Октомври 2011 Автор Доклад Share Публикувано 26 Октомври 2011 От това, което разбрах, ще избирам между марките Континентъл, Мишлен и Гууд Иър, според зависи какви имат, че чух за проблеми с наличности нещо и не е сигурно, като ида дали ще намеря каквото ми трябва. Адрес на коментара Сподели в други сайтове More sharing options...
PESHO OT MARS Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 (Редактирано) Моите скромни наблюдения са че специално Мишлен и Гудиър първата година са страшни и после са мазало. Вобще не могат да се доближат до това което са били.Доколкото знам Контито си запазва качествата далеч по-добре. TS830 масово мои познати го карат вече 2-3 сезон и са доволни като гума.Понеже лично за себе си нямам толкоз кинти си купих миналата година едни Dayton DW510, представянето им из София не беше на висота но разбрах че и доста "маркови" гуми са се представяли по подобен начин заради смесите за размръзване използвани миналата година. Тази година ще видя как е положението. Редактирано 26 Октомври 2011 от PESHO OT MARS Адрес на коментара Сподели в други сайтове More sharing options...
Don_Diego_ Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 asenovb мисля, че Контито го има налично Адрес на коментара Сподели в други сайтове More sharing options...
asenovb Публикувано 26 Октомври 2011 Автор Доклад Share Публикувано 26 Октомври 2011 Аз съм си харесал моделът с обозначение P накрая, дано го имат. Адрес на коментара Сподели в други сайтове More sharing options...
Don_Diego_ Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 Малка поправка: Има само Т830 налично на този размер. TS830P имаше няколко бройки в самото начало на сезона Адрес на коментара Сподели в други сайтове More sharing options...
asenovb Публикувано 26 Октомври 2011 Автор Доклад Share Публикувано 26 Октомври 2011 Еее, на мен точно този модел ми трябва. Шет А дали ще заредят нови количества? Адрес на коментара Сподели в други сайтове More sharing options...
Don_Diego_ Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 Не знам, прозвънявай ги периодично центровете Адрес на коментара Сподели в други сайтове More sharing options...
asenovb Публикувано 26 Октомври 2011 Автор Доклад Share Публикувано 26 Октомври 2011 А някъде другаде мога ли да ги намеря, ти имаш ли ги??? Адрес на коментара Сподели в други сайтове More sharing options...
Don_Diego_ Публикувано 26 Октомври 2011 Доклад Share Публикувано 26 Октомври 2011 Утре ще проверя какво имам и ще пиша вечерта Адрес на коментара Сподели в други сайтове More sharing options...
wolff1 Публикувано 27 Октомври 2011 Доклад Share Публикувано 27 Октомври 2011 А някъде другаде мога ли да ги намеря, ти имаш ли ги??? http://ssl.delti.com/cgi-bin/rshop.pl?details=Ordern&cart_id=72165513.153.12688&typ=R-172354&ranzahl=4&Breite=205&Herst=Continental&Quer=55&Felge=16&weiter=0&kategorie=6&Ang_pro_Seite=20&Transport=P&dsco=153&sowigan=Wiно май ще са ти извън бюджета. Адрес на коментара Сподели в други сайтове More sharing options...
asenovb Публикувано 28 Октомври 2011 Автор Доклад Share Публикувано 28 Октомври 2011 (Редактирано) Не знам защо, но в този сайт са със сто лева по-скъпи от Диана с клубната отстъпка 25%, а и без отстъпка пак идват по-евтино?!!! Редактирано 28 Октомври 2011 от asenovb Адрес на коментара Сподели в други сайтове More sharing options...
BECKO Публикувано 28 Октомври 2011 Доклад Share Публикувано 28 Октомври 2011 Някои марки са по-скъпи, други по-евтини.... всичко зависи на кой от големите производители е дилър съответния сайт / магазин Доколкото си спомням Goodyear са на прилични цени в Делтиком (този сайта), а и идват от Германия - не са на склад в БГ Адрес на коментара Сподели в други сайтове More sharing options...
